easiest way to remove emblems from rear???
Old Mar 4, 2003
Shadow's Avatar
Shadow is an unknown quantity at this point
i read the DIY on removing the emblems, it says use a screwdriver wrapped in a towel and some "goof off" and then wax the area...
i remember someone saying something about a hairbloser and some dental floss or some waxed string?!?!!?
anyone know what i'm talking about? or have any better suggestions for both the easiest way and/or to get the best results??? thanks for your help
Old Mar 4, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
I just griped mine with my hands after my car was sitting out on a hot summers day and started to pry them off.. Took a bit of grunt but I got um. Try just using a heat gun and then pulling them off by hand.. But yeah, the floss stuff should work
~nick~
Old Mar 4, 2003
Zzyzx's Avatar
Autocross Junky
It depends on if you care if you brake the emblem or not.
I used what is called a "spoon" Its basically a long slim strip of plastic that wont mar the paint and pryed them off. this is what a body shop typically uses.
or if you dont care if you brake them, just grab an edge an pry it off with your fingers. both ways will leave some of the double sided tape on the car, and there are several ways to take that crap off.
one way is to just rub it off with your finger (this can hurt but you dont put any cemicals on the paint)
or you could get some laquer thinner and wipe it off (this can hurt your paint if you leave it on to long.)
or you can find a can of Speedy 500 and do the same (This stuff is great, it shouldnt damage the paint and works well but it can be a bit messy)
waxing the area isnt going to do much, what you need to do is after the emblem is off, check if there is anny residue (ushally in the shape of the emblems out line) if there is some, you need to clay the area to remove it.
Just so you know the H has centering holes in it. so if you remove that one youll have holes in your deck lid.
good luck with that.
I just remembered, I dont recomend using a heat gun, you can warp the metal and damage the paint.
Old Mar 4, 2003
abmerop18's Avatar
Jam out with your clam out.
i used a hair dryer and some fishing line. it was fairly simple. u dont really need the hair dryer, but it helps a bit. dont use dental floss, it breaks too easy. fishing line is the best thing to use to remove the emblems.
Old Mar 4, 2003
dragoon's Avatar
dental floss worked quite well for me.
Old Mar 4, 2003
KeNsHiN's Avatar
LEVA
hair dryer is the best because it isn't as hot as a heat gun, but does the job
Old Mar 4, 2003
born2xLr8's Avatar
dental flow always broke on me. I used fishing. The string method will work if you prefer not to break the emblems.
Old Mar 4, 2003
Duckor's Avatar
Duckor is an unknown quantity at this point
go with the blow dryer... easiest way. use a wrapped screw driver to pry it a little and if you keep it heated it should peel right off with just your hand. i didnt use goo gone or anything. I just rubbed the rest of the glue off with my fingers.
Old Mar 4, 2003
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Yeah I used a hair dryer, and dental floss and it worked great, too bad my dealer put my EX emblem on with super glue so some of the paint came off on my bumper so I had to repaint and sill have part of the upper X in super glue stuck on my bumper. [IMG]i/expressions/face-icon-small-mad.gif[/IMG] since I didn't want to have to put more touch up paint on it.
Nick
Old Mar 4, 2003
Juggaman's Avatar
Juggaman will become famous soon enough
I just used a hairdryer and my hands. The emblems basically fell off without any pulling at all. Came off completely...didn't even have to use any goo-gone.
Old Mar 4, 2003
Dr5D's Avatar
I just used dental floss all by itself and they came off fine, but the floss did break quite abit. probably that fishing line is a better idea[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 4, 2003
2k1CivEX's Avatar
Phi Gamma Delta - Univ. of Toledo
2k1CivEX will become famous soon enough
well, when I did mine, I tried using dental floss first, and for some reason it didn't work so well, but what I tried next worked awesome....
take a towel, and then run the edge of it behind the emblem..the whole thing came off clean....best way IMHO
Hope that helps, Eric
Old Mar 4, 2003
rasper's Avatar
rasper is an unknown quantity at this point
I just did mine this past weekend using a hair dryer and my fingers. I used some rubbing alchol to get the rest of the adhesive off. The alchol did not damage the paint. Looks great.
Old Mar 4, 2003
7thGenerasianCivic's Avatar
Floss it! Then alcohol, wax it after.
Old Mar 4, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Quote
[hr]Originally posted by: dragoon
dental floss worked quite well for me.[hr]
The last time I used dental floss was for this.
You can just pull the H emblem off.
Old Mar 4, 2003
Shadow's Avatar
hey guys, i took you're advice as a whole and did this:
1-hairblower...
2-screwdriver wrapped with a towel...
3-then rubbed off any excess residue with the towel...
it's awsome!!! you guys were right!!!! it was easy AND looks good!! thanks again for your help, i appreciate it...
Old Mar 4, 2003
lidcivic's Avatar
lidcivic is an unknown quantity at this point
I used waxed dental floss...Then peeled the double sided tape off, and then cleaned the area with paint cleaner ... Easy!
Old Mar 4, 2003
reytito's Avatar
yah i took an iron chisel and and hammer and chiseled the emblems off. i also left these sweet *** looking gashes in the paint. Its SOOOOO sweet. j/k, blowdryer, fish string, BINGO.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
alex_nyc
Jun 18, 2015 11:45 AM
SoyerOner
May 11, 2015 09:46 PM
JoeNC
Dec 22, 2001 03:18 PM
Civicchik01
Dec 7, 2001 06:33 PM
