Valve Cover Painting
Old Feb 18, 2003
binky's Avatar
binky is an unknown quantity at this point
what happened to the link to the DIY valve cover painting? i really wanted to do it this weekend, can anyone help?
Old Feb 18, 2003
cdmx's Avatar
Its like painting anything, sand it down a lil so its a lil rough so the paint will stick but not rough enough that it will show through the paint.
Then add a coat of primer, really only one coat is necessary, if your painting it a dark color use a dark primer light color light primer.
Then add 2-3 coats of the base paint whatever color you want it....I suggest one of the 500 degree paints
Then add 2-3 coats of clear coat/gloss and you should be fine let it dry! - I put my stuff in front of a heater they dry faster....Also I bought 500 degree clear coat so use that also.
Old Feb 18, 2003
XxJDMCivicxX's Avatar
Do you really have to primer I heard it wasn't necessary and my friend accidentally used touch up paint on his does that make a difference cuz I heard the valve cover doesn't get that hot?
Old Feb 18, 2003
binky's Avatar
thanks, that helps a lot, any certain brand of paint you recommend? is the sanding down necessary? what color did you do yours...thanks
Old Feb 18, 2003
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
No, do you don't have to sand it, prime it, or coat it. Nor does the paint matter (although water colors probably won't work). I used enamel modelling paint. It's oil based that I had left over from building a couple models. You can pick up a little bottle at a hobby store for like $2.00. I just painted several coats (allowing it to dry inbetween). If you want to paint the letters, just use tape and mask off the other parts. If you're worried about the paint melting, it won't. I drove about 150 miles back from middle tennessee one night and once I parked the car, I popped the hood and took off the valve cover. It was still cold. I've had my cover painted for a few months, and I've had no problems with the paint. Good luck!
These pics have some glare, but it's as good as I got.
Old Feb 18, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
Quote
[hr]Originally posted by: RyzRocket02
No, do you don't have to sand it, prime it, or coat it. Nor does the paint matter (although water colors probably won't work). I used enamel modelling paint. It's oil based that I had left over from building a couple models. You can pick up a little bottle at a hobby store for like $2.00. I just painted several coats (allowing it to dry inbetween). If you want to paint the letters, just use tape and mask off the other parts. If you're worried about the paint melting, it won't. I drove about 150 miles back from middle tennessee one night and once I parked the car, I popped the hood and took off the valve cover. It was still cold. I've had my cover painted for a few months, and I've had no problems with the paint. Good luck![hr]
he said VALVE COVER not WIRE cover....... ill see if i can dig up my pics from the DIY on the valve cover
Edit.. umm just waitin for that asked the Q to clairify if he wants the VALVE cover painted.. or WIRE COVER.. lemme know.
Old Feb 18, 2003
NeonImpact's Avatar
Forum Sponsor
DIY Valve Cover, not Plug Cover...
Old Feb 18, 2003
binky's Avatar
i was talkin about the valve cover, but both would be great.
Old Feb 18, 2003
Vesper's Avatar
Vesper is an unknown quantity at this point
the only hard part about painting the valve cover is getting the dam thing out. and yes light sand it.
Old Feb 18, 2003
dragoon's Avatar
and it would be best to use some sort of heat-resistant paint
Old Feb 18, 2003
cdmx's Avatar
Quote
[hr]Originally posted by: Vesper
the only hard part about painting the valve cover is getting the dam thing out. and yes light sand it.[hr]
Yes, the purpose of lightly sanding is to make the paint stick, if your not going to use a primer its wise to sand too but it doesn' t cost that much....Wal-mart engine paint will work fine[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Quote
[hr]Originally posted by: dragoon
and it would be best to use some sort of heat-resistant paint[hr]
Yes to be on the safe side use heat-resistant paint too
Old Feb 19, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
DIY????
Old Feb 19, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: XTREME2K2CIVIC
DIY????[hr]
do you want to know what a DIY is or something?
DIY = Do It Yourself
Old Feb 19, 2003
Reppin Stage 7
Quote
[hr]Originally posted by: FlyRiceRacer02
Quote
DIY????[hr]
DIY = Do It Yourself[hr]
I ment if anyone had a do it yourself for removing the valve cover...
Old Feb 19, 2003
CarbonFly's Avatar
Quote
[hr]
I thought it was wierd that a member who was here as long as you would know what DIY stood for........lol
Civic15
18
Sep 19, 2017 07:48 PM
Misfit2613
Jul 30, 2015 09:49 AM
hoofboy
Jul 17, 2015 04:27 PM
General 7th Gen
Jul 9, 2015 10:17 PM
BootyDo
Jul 7, 2015 06:06 AM
