Chevy Engine...
Old Dec 11, 2002
Mystic3030's Avatar
Yup, i'm an A$$hole.
Chevy Engine...
I know this is kinda off topic....but does anyone know what the biggest small block engine chevy ever made was?
Old Dec 11, 2002
Dagooseisloose's Avatar
Dagooseisloose is an unknown quantity at this point
400 they made that in a small block and a big block
Old Dec 11, 2002
Gryphin's Avatar
00 Hatchback Owner
Quote
[hr]Originally posted by: Dagooseisloose
400 they made that in a small block and a big block[hr]
friends got that eninge in her 74 silverado lol it goes
Old Dec 11, 2002
mohawkboom's Avatar
427 aluminum block in vette's...called the 427 "tuned port injection" ...I own 1 (engine not the car)
Old Dec 11, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
i thought the biggest small block was a 400 CI isn't the 427 just a stroked 400?
Old Dec 11, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: BigHippo22
i thought the biggest small block was a 400 CI isn't the 427 just a stroked 400?[hr]
it's a factory stroked 400 so it's a 427" but yes..same block externally
Old Dec 11, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
dingdingding! you win the prize!
Old Dec 11, 2002
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
this is going to sound dumb, but what is the difference between a small block and a big block, iv'e also heard the tearm long block??
Old Dec 11, 2002
mohawkboom's Avatar
Small block is the outside dimensions of the engine..GM uses basically 2 blocks, both with different bores and strokes..but for the most part identical size on the outside.. a Small block is your standard 305 and 350 block...from bottom to top it's pretty short.. about 28" across or so...
a Big blck, like the 428 and 454 uses much larger cranks and bigger bores..and the engine is quite a bit larger and less compact in design.
a Long block has nothng to do with the size or type of engine..it refers to the parts included with the block... a Long block crate motor includes all neecessary parts to run(block, heads, pistons, rods, oil pan, crank etc.), except engine accessories like alternator, Plug wires..
a Short block is litelly just the cyclinder block itself
Old Dec 11, 2002
HondaGuru's Avatar
the block size determines weather its classified as a big or small block. and im talking about the actual block and not the internal engine volume. a 400 CID block stroked to 427 would be a "small" block still, however if the blovk it self was 427, then it would be a "large" block.
short blocks are the lower portion of the engine, ie an engine without the head. long blocks are the entire engine.
Old Dec 11, 2002
HondaGuru's Avatar
428? r u sure about that size?
Old Dec 11, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: HondaGuru
428? r u sure about that size?[hr]
yup... Police pack de-stroked 454's found in alot of late 70's to mid 80's Chevy caprice intrceptor models...instead of the standard 305...
Dobber1
Jul 10, 2015 11:17 PM
Genyc07
Jun 28, 2015 04:55 PM
pantdino
15
May 13, 2015 02:22 PM
iluvbritney
Mar 8, 2003 05:19 PM
ecliptiCz
Jan 31, 2002 04:10 PM
