Hydrocarbons?
Hydrocarbons?
Is there any way to lower HCs? I mean in emissions. I just had to get my other car inspected and it failed. It was at like 270 and the passing was 220. I passed the CO ok, tho. Maybe cleaning the air filter and changing the spark plugs? Can anyone think of anything else I might be able to do instead of spending money at some service station?
For those who don't know HCs represent a lean fuel mixture, i.e. too much fuel is not being burned in your shitty inefficient engine.
yeah, heat will help. I've been thinking of changing the thermostat because I belive it's stuck in the open possiton. I'm going to get a 195 from NAPA and see if that helps.
Well, if you replace the thermostat get another 180 degree one. If the engine runs too hot you'll risk getting predetonation. Also, you might want to clean the carbon buildup in your EGR passages.
Actually, I think I'm just going to take it to a local shop and tell them to do some work on it NOT TO EXCEED $160!!!! The reason why is because if I have a receipt for over $150 in repairs by a certified place I can get a waiver for my emissions test. Just some more money to toss down that damn money pit! Whomever said that when you buy a used car you inherit another mans problems was dead on!
Quote
[hr]Originally posted by: silverdevil
For those who don't know HCs represent a lean fuel mixture, i.e. too much fuel is not being burned in your shitty inefficient engine.[hr]
have you checked the plug gap lately? can contribute to inefficient fuel burning...
-AND- usually its running FAT, not LEAN... (lean = less fuel/more air) to make more hc's... try leaning out the mix
edit: brain wheels are a turning
what oil do you run in it now? you can try a straight weight oil to lessen the oil burning, which will also help bring hcs down (if your burning a lil bit o' oil)
This problem is so obvious and so easy to fix..it's caused by a rich fuel mixture by the way....get your injectors vacuum cleaned and change your plugs..
Your injectors are probably streaming gas into the cylinder instead of misting it in...shouldn't cost you more than $75-80
Quote
[hr]Originally posted by: avenger
yeah same thing, fat is more domestic car slang...[hr]
Quote
[hr]Originally posted by: PESTLNC
FAT? Never heard that before...do you mean RICH?[hr]
Quote
[hr]Originally posted by: mohawkboom
Your injectors are probably streaming gas into the cylinder instead of misting it in...shouldn't cost you more than $75-80[hr]
Oh, and I did mean running rich but I just typed wrong. you know how that goes. I was going to do the job myself because I didn't know about the waiver but then I read the paper they gave me and decided to have someone do it. Thanx for the input!
CivicsClass101
Jul 9, 2015 11:14 AM
ivanhatch
Oct 16, 2012 10:16 AM
gearbox
Sep 8, 2004 08:57 PM
