nitrous problem...
Old Nov 9, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
nitrous problem...
does anyone who uses nitrous have a problem starting their car 5-10 minutes after squeezing??i had trouble w. it. it started and died out really quick.then i restarted the car and it idled at 300 for a while... i dunno whats goin on w/ it
Old Nov 9, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
what kind of kit, how much of a shot. what sort of plugs are u running, when was the last time you checked/changed them? i need more information.
Old Nov 9, 2002
civichx81's Avatar
holley's NOS kit. 80 shot.denso iriduim. plugs are a week old. i squeezed for 5 seconds about 3-4 times.stopped at blockbuster video to get some dvds and got in the car and had the problem
Old Nov 9, 2002
HondaGuru's Avatar
80 shot wet or dry.
Contrary to what ricer magazines say, iridium plugs are crap. Yes they will last longer in a stock car, so you don’t have to change them until every 100K miles or so, but they will MELT under nitrous and boost applications. Change them out for some NGK-BKR7Es, gap them to stock specs, and that should solve your problem.
Old Nov 9, 2002
HondaGuru's Avatar
from the clubsi.com nitrous forum's spark plug thread:
we recommend ngk bkr7e
its a colder heat range then stock and have been proven to be the best for n2o in our cars "dyno tested"
Do you recommend Iridum plugs...
NO we do not iridum plugs from many many honda people that tried them and did NOT listen to us "they listened to hype" had them break when spraying and cause major engine problems
Do iridum plugs give me more horse power?
if your plugs were very dirty and worn before replacing then yes,, but so would other plugs but other plugs would last longer under spray
I see white spots on the plugs...
you are detonating you need to add more fuel or adjust the timing back "the second is prob better"
Do the plugs come gapped? what should they be gapped at?
They should come gapped but you should always check them "all the ones dave and i bought have been gapped".. they should be gapped at .038 unless you run after market ignition then you can bump it to .041
Old Nov 9, 2002
civichx81's Avatar
ok cool, thanks for the help. ill try that. how much do those plugs run?40 bux?
Old Nov 10, 2002
HondaGuru's Avatar
hahaha! 40 bucks? maybe for a box of them. I pick them up for 10 dollars per set of 4 at my local race shop. you can get them from summitracing.com if u wish, or many other places.
ttamrekab
Sep 28, 2015 01:22 AM
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
2k2civicballer
19
Apr 26, 2002 01:57 PM
supermex
Feb 1, 2002 09:05 AM
