how do i make my car backfire??
Old Oct 30, 2002
Element2k5's Avatar
Element2k5 is an unknown quantity at this point
i just think it would be cool for my video that im doing... so if u know how to make my car backfire... ill give u props in my video...
Old Oct 30, 2002
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
You mean backfire as in a flme coming out of your exhaust?? If yes, guys put a sparkpulg in their tailpipe with a switch to make a spark.
Old Oct 30, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
Old Oct 30, 2002
Element2k5's Avatar
well i kinda dont wanna run extra wires into the exhaust....
yes shoot flames out of my exhaust.....
Old Oct 30, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
well, in my car, if i rev it up to like 4 grand, jump off the throrrle, and keep bliping the throttle on and off real quick i can usually get it to load up and backfire....but i dont do this often considering its generally not good for the car.....even take the risk of blowing valves and stuff....not good [IMG]i/expressions/demon.gif[/IMG]
Old Oct 30, 2002
Element2k5's Avatar
Quote
[hr]Originally posted by: mwwhonda
well, in my car, if i rev it up to like 4 grand, jump off the throrrle, and keep bliping the throttle on and off real quick i can usually get it to load up and backfire....but i dont do this often considering its generally not good for the car.....even take the risk of blowing valves and stuff....not good [IMG]i/expressions/demon.gif[/IMG][hr]
by jumping off the throttle u mean just letting it go?
Old Oct 30, 2002
Element2k5's Avatar
so do u do this while u are driving or just idling?
Old Oct 30, 2002
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Old Oct 30, 2002
Neonmike's Avatar
Neonmike is an unknown quantity at this point
You'd need like an MSD ignition that cuts the spark with the rev limiter.
Old Oct 30, 2002
VNlilMAN's Avatar
The Standard One
www.autoloc.com
has something that does it
Old Oct 30, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
Another victim to the Fast and the Furious...
We've all been there.
Old Oct 30, 2002
65Coronet440's Avatar
65Coronet440 is an unknown quantity at this point
The sparkplug trick will only work if you have something injecting fuel towards the end of the exhaust as well, i.e. propane. Cars these days are way to efficient to have raw fuel or extremely rich fumes flowing out the tail pipe, which is what you need to spark a flame. Back in the day of manual chokes, you could pull your choke out, richen the motor till it about dies and that would be enough to get you some flamage, but that was also through non-catalatic exhaust systems with low restrictions.
With a factory exhaust, I really doubt you could get a flame out the back by getting it to backfire, although I might be wrong. The cars that usually do that have mostly straight through, low restrictive exhaust that don't stop the flame from being passed all the way through. You can also blow your exhaust apart with a backfire, so good luck with that.
The definition of a Backfire is: Passage of unburned fuel mixture into the exhaust system where it is ignited and causes an premature explosion. Note: EXPLOSION
Hope this helps!
Old Oct 30, 2002
mikalem's Avatar
mikalem is on a distinguished road
Hmmm hope you got another few grand laying around to take care of the damage you are gonna cause setting your car on fire [IMG]i/expressions/face-icon-small-smile.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG]
Old Oct 30, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
Yeah my dad was tellin me that back in his day, guys would put spark plugs in the exhaust and just wire it back and then when they wanted flames, they would turn off the car and just pump the gas (again, not recommended with fuel injection, this was when they were still using carbuetrators) and then turn on the car and it usually it did. Now, when you usually see cars that have fuel injection do it, its usually because they are running the car really hard then they downshift 1 or 2 gears, get off the gas and then get back on it really quickly. You can try it but, its not worth the damage.
Old Oct 30, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
A 'misfiring system', (as put by the series Initial-D), if I'm not mistaken is usually a sign of an engine with advanced timing running race gas.
Old Oct 30, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Apparently on the way back from a NE get together, Grey and Havok2k1 said I backfired when I downshifted on the highway, and the backfire sounded like it was coming from the intake...I didn't hear it because I had the window down and the music blaring, but he might have it on tape...methinks it's time to check the timing in my car [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Oct 30, 2002
Explosivo's Avatar
The dog told me to do it
Explosivo is an unknown quantity at this point
Not trying to flame, but ISN'T THIS STUPID? I mean, ignited fuel in the exhaust? That can't be good. Besides, if you are making a video, why not create a particle system in Lightwave or something. Even superimposed flame footage, but actual flames from the exhaust? FLAMES FROM THE EXHAUST!?! What are you doing, a remake of Grease?
Old Oct 30, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
You are absolutly right. Some poeple in this thread are in need of a swift kick to the nuts.
Old Oct 30, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I with the rest of you guys.
This might not be the smartest idea but hey if it works for you then go for it I guess, I just dont know if its worth killing your car for a video. If you want to try and backfire, the I could suggest adding some of that NOS Octaine booster to your fuel, I have a few friends that did that and it killed their engines, and they smoke and backfile all the time...........
Good Luck though man.
Old Oct 31, 2002
AR's Avatar
AR
e-married to daydreamer
had to do it.
Old Oct 31, 2002
aetobatus's Avatar
n00b
aetobatus is an unknown quantity at this point
Quote
[hr]Originally posted by: AR
had to do it.[hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
McD
Apr 16, 2015 10:46 AM
SSMatey
Apr 13, 2015 06:09 PM
crazydragon
Nov 7, 2001 05:13 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
