Project K20A type R HAS Begun
Old Nov 16, 2002
  #61
speed werx's Avatar
speed werx is an unknown quantity at this point
cosomo: if you read posts, youd know that im having pics and info on my site as this swap goes along
Old Nov 18, 2002
  #62
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Quote
[hr]I was just wondering if you know that adding octane+ to 93 octane gas actually doesn't do anything for your octane......Anyway, I was wondering if you could take LOTS of pictures, as I am planning to do this swap also, and if it's not too much trouble, maybe a parts list?? Any little bit is appriciated!! [hr]
I've done tests back in high school where the octane level has increased using 87, 89 and 93 octane automobile gas with an octane booster. We found more deposits and slower burning of the combustin chamber. We also think it got better miles but it was a lawn mower and it's not like we rode it around to see the results heh. I think it will work, but I don't know why regular 93 can't be used daily.
Old Nov 22, 2002
  #63
FiremanJoe's Avatar
FiremanJoe is an unknown quantity at this point
are u goin to be able to keep the ac with the swap? ive heard thats theyres no room
Old Nov 22, 2002
  #64
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
A/C and Power steering stays. All you have to do is have or get new hoses and lines for everything. There is enough room for everything.
Old Nov 25, 2002
  #65
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Old Nov 26, 2002
  #66
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
This is gonna be nice
can't wait to see it.
anyone heard from H town recently on how his engine is holdin up?
Old Nov 27, 2002
  #67
speed werx's Avatar
well mounts should be out in the next week or so..so we'll have the subframe and the other ton of OEM parts needed for the swap delivered around the same time i think. cant wait to get the ball rolling some more
Old Dec 3, 2002
  #68
DC5@EM2's Avatar
Here some new info for you guys. The mounts should be out in like 2-2 1/2 weeks or so once they are on sale, im ordering them and then this swap should get under way. Thats about for info but ill keep you guys posted. Later.
Old Dec 11, 2002
  #69
DC5@EM2's Avatar
Heres some more info for you guys, the mounts wont be shipped till jan 1 [IMG]i/expressions/face-icon-small-sad.gif[/IMG], but there is some good news. Ive been thinking about it and im going to do a 5 lug 2k2 ITR brake conversion including the rear. I ordered the ITR Brembo brake conversion from jdmhondaparts and should be getting it soon. Just thought I should pass this along to you guys. Later.
Old Dec 11, 2002
  #70
Rider's Avatar
Rider is an unknown quantity at this point
Quote
[hr]Originally posted by: VeNoMsCiViC
Heres some more info for you guys, the mounts wont be shipped till jan 1 [IMG]i/expressions/face-icon-small-sad.gif[/IMG], but there is some good news. Ive been thinking about it and im going to do a 5 lug 2k2 ITR brake conversion including the rear. I ordered the ITR Brembo brake conversion from jdmhondaparts and should be getting it soon. Just thought I should pass this along to you guys. Later.[hr]
Yeahhhhhh good thing to do...!! Keep posting...!!
Eric
Old Dec 12, 2002
  #71
cosmicjim's Avatar
cosmicjim is an unknown quantity at this point
how are you going to deal with the rear? are you going to grab parts off a wrecked EL or SiR?
Old Dec 12, 2002
  #72
DC5@EM2's Avatar
I still have to talk to briang about this, but they were able to do a 5 lug conversion on all four wheels using rsx parts, so thats what i want to do.
Old Dec 13, 2002
  #73
Hawk's Avatar
You boost, I-VTEC
i will be joining you and your swap fun venom. not for at least a year, but i will.
Old Dec 13, 2002
  #74
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: Hawk
i will be joining you and your swap fun venom. not for at least a year, but i will.[hr]
Sweet! Good luck to you too Hawk!
Old Dec 13, 2002
  #75
whitevic's Avatar
whitevic is an unknown quantity at this point
doing the rear disc brake conversion is actually pretty straight forward. the good news is that you shouldn't have to switch master cylinders, i'm not totally done with mine yet (cause the place i ordered the rear suspension from sent me one that has a bent spindal) but everything appears to work fine. it does just bolt right on just so you know.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] new2.JPG (20 Kb)
Old Dec 14, 2002
  #76
cosmicjim's Avatar
whitevic ... mind give me a quick parts list? I see you have a 5 lug conversion as well, i want to keep 4 so i dont have to fiddle with the fronts.
Old Dec 14, 2002
  #77
Hawk's Avatar
You boost, I-VTEC
Quote
[hr]Originally posted by: Grey
Quote
Sweet! Good luck to you too Hawk! [hr]
thanks, once i finish my suspension in my car im gonna start saving up, its gonna take me about a year to save up the cash but i will be doin it. screw my little d17. It'll give me and my friend something to do, little winter project.
Old Dec 15, 2002
  #78
whitevic's Avatar
cosmicjim: you will need the rear lower control arm, upper control arm (just get a new camber piece), abs line, rubber line to caliper, emergency brake cable, and the brake assembly itself. if you use the rsx strut/spring setup the ride height will be fine, if you use what i did, using koni and ground control from the civic then connect that to the lower control arm that alone will drop your car 1 inch. to attach the emergency brake cable, you will have to take appart your console, but it just bolts right in, with no other modifications or anything.
Old Dec 15, 2002
  #79
DC5@EM2's Avatar
Quote
[hr]Originally posted by: whitevic
cosmicjim: you will need the rear lower control arm, upper control arm (just get a new camber piece), abs line, rubber line to caliper, emergency brake cable, and the brake assembly itself. if you use the rsx strut/spring setup the ride height will be fine, if you use what i did, using koni and ground control from the civic then connect that to the lower control arm that alone will drop your car 1 inch. to attach the emergency brake cable, you will have to take appart your console, but it just bolts right in, with no other modifications or anything.[hr]
Just one question for you. Did you have to change the outer joints in the front for civic axles to work because I know the bolt pattern inside the hub is bigger on the rsx than the civic. thats the reason why you have to change out the outer joints when doing the k20 on your rsx axles.
Old Dec 15, 2002
  #80
whitevic's Avatar
venomscivic: all i had to do to get them to fit with absolutely no problems was to take a 5/8 inch drill bit and drill them out. with doing that they mounted up perfectly, using the rsx bolts even. the front was more tricky to do, and took a lot more time, but was well worth it. the picture isn't that great, but if you would like i'll get you a better one, just let me know.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACF95A.JPG (12 Kb)
Old Dec 17, 2002
  #81
DC5@EM2's Avatar
I thought that I should kinda post the pics up here now since its getting close to install. I just ordered the mounts today and everything should get going after the 1st of jan. I can't wait, well here are some pics. Later.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic001.JPG (26 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic002.JPG (27 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic003.JPG (40 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic004.JPG (45 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic005.JPG (47 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic006.JPG (28 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic007.JPG (48 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic008.JPG (26 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic009.JPG (47 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic010.JPG (44 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic011.JPG (48 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] K20A pic012.JPG (28 Kb)
Old Dec 19, 2002
  #82
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
im jealous. [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 20, 2002
  #83
CIVIC2NV's Avatar
CIVIC2NV is an unknown quantity at this point
GOOD JOB!!!
hey how much did u pay for the K20?
I am wanting one so badly, where can i get one,
and how much,
will they fit in the 2001 civic coupe LX?
how much does is it to install?
Old Dec 20, 2002
  #84
Hawk's Avatar
You boost, I-VTEC
Quote
[hr]Originally posted by: CIVIC2NV
GOOD JOB!!!
and how much,
how much does is it to install?[hr]
boy are you new here.[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Search for k20, you'll find all the info you need
Old Dec 20, 2002
  #85
StLVtec's Avatar
StLVtec is an unknown quantity at this point
ABuddy of mine just ordered his K20 type R yesterday, he paid 6200 for everything. His car will be back in March its getting sent out tommorow. They just stripped everything off the car. He has lots of stuff for sale btw, his car is red. Its geting stripped because he is getting Meredes Benz S type conversion headlights and tailights, getting candy apple red paint and widebodied. Its going to be raw. And his car is on 19's
Old Dec 21, 2002
  #86
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Can't wait for the final product!
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
skeener51
Oct 1, 2015 05:56 PM
C-Hamm
Sep 28, 2015 10:31 PM
anubis62
Sep 27, 2015 12:56 AM
