Went to Drags (RSX Type-s)
Old Oct 14, 2002
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
Well I went to the drag races sunday night and saw some tight *** rides. one race was a supra vs a corvette z06. it was about even until the supra pulled away at the end. there was also this yellow s2000 kicking *** and a black 6thgen civic w/ supercharger dominating as well. my friends told me what I was going to do to my car. I said an engine swap w/ a RSX type s engine. they thought i was crazy. I told them its been done before. i just had one question, w/ a rsx type s engine and turbo w/ basic i/h/e, what times should i expect on the 1/4 mile? thx
Old Oct 14, 2002
VNlilMAN's Avatar
The Standard One
you do know that that setup will run about $15,000. also one thing your going to have to worry about is the returnless fuelline. Moocow has a turbo and was only running 5 psi because he didnt get internals but the returnless fuelline was also stopping him from going higher as well.
Old Oct 14, 2002
Cyclosporine's Avatar
Cyclosporine is an unknown quantity at this point
actually the question should be...will an RSX type S engine swap into my small engine bay after I loose my power steering allow enough room for a turbo...and an intercooler???????
if you have the $$$ you can...
anyway, in respond to your answer...I would say...if you put an RSX type S engine...and a turbo with enough boost and and exhaust ('cause with the turbo the intake has to be part of the turbo and the header is replaced), and the small weight of the civic...and if you're a really really really good drive....possibly high 13's....or in average....low to mid 14's
Old Oct 14, 2002
VTECTypeR's Avatar
you should be able to get 13's easily with a turbo.
Old Oct 14, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
low 13s with that setup but as vnlilman said, prepare to pay 15000+ for that setup,
Old Oct 14, 2002
TYPE7RS's Avatar
TYPE7RS is an unknown quantity at this point
must be nice to be made of money
Old Oct 14, 2002
Nuts's Avatar
Nuts is an unknown quantity at this point
are you crazy...low to mid 14's with a turbocharged type-s in our light civics. no way unless your an absolutley horrible driver.
Old Oct 14, 2002
dacivic's Avatar
dacivic is an unknown quantity at this point
HKS solved the returnless fuel system, so I believed you could run more than 5psi.
Old Oct 14, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
its not rocket science to install a return line, all you have to do it find it, block it from regulating and add the FMU or FPR for adjustable fuel pressure
Old Oct 14, 2002
JohnnyLee's Avatar
7thgen guh chee
Only 13's huh?
Old Oct 14, 2002
mohawkboom's Avatar
If your gonna run boost the Type_S engine is the wrong one to use.. too high a compression ratio... you'd want a base RSX Engine.. which will fit..you'd have room for a turbo.. a header would be impossible as you'd be using a Turbo manifold.. Running a return line for the fuel system and swapping to an Older acura Intagra fuel pump would allow you to run 7-8 PSI boost somewhat safely.. But with stock internals the engine will wear very quickly. To do it the right way you'd have the block sleeved, get reinforced connecting rods. Change the head bolts to ARP studs. port then intake manifold for better flow..otherwise you'll have very little high end power gains caused by restriction....Done the cheap way with just a swap and custom turbo kit..your engine won't last 30k miles before it needs a full overhaul....
Make sure you learn as much as possible before considering spending that amount of money.
PunX
Sep 23, 2015 10:45 PM
krazykoncepts
Sep 8, 2015 09:02 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
lexus300
Aug 16, 2015 04:28 PM
