Exactly how bad is brake torquing?
Old Sep 14, 2002
IronFist's Avatar
I searched.
So I understand that it ruins your brakes, but exactly what is the extent of the damage? Is the damage caused by holding the car at high rpms? Or is the damage more due to the length of time that you hold the brakes for while the wheels are trying to turn?
Or is it not even that bad at lower rpms (<2500)? I'm assuming if you power braked from like 5000 rpm it might be bad, but is lower that bad?
It's not like I'm gonna do it every day, so no flames. I'm just curious about it from a structural standpoint.
IronFist
Old Sep 14, 2002
Ducatti's Avatar
Ducatti is an unknown quantity at this point
You probably wont be able to brake torque higher than 5k anyways, the brakes would hold under that much pressure...It also heats up the tranny pretty bad too
Old Sep 14, 2002
Collective's Avatar
Collective is an unknown quantity at this point
On domestics with V-8's with RWD and "strong" automatics seem to favor this, with minimal problems. But for FWD imports with stock trannys WILL have a shorten life span. I just don't think its worth it unless you beef up the drivetrain... (Either way your looking at spending some bucks...)
Old Sep 14, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
Quote
[hr]Originally posted by: EvilDave666
lol man, you are asking the wrong people. Everyone here is all "how do i connect my washer LEDs."[hr]
too true.
Old Sep 14, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
you need a higher stall speed on your torque converter to be able to launch at higher RPMs like that.
Old Sep 14, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Quote
[hr]lol man, you are asking the wrong people. Everyone here is all "how do i connect my washer LEDs[hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 16, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
Brake-torqueing works, but so does neutral dropping. Both have adverse effects. Neutral dropping will start to shred your trannie, and brake-torqueing will start to shred your torque-converter. Most people will agree that brake-torqueing is less damaging, mainly because you could theoritically loose your trannie from a single neutral drop.
Old Sep 16, 2002
Toad's Avatar
Toad is an unknown quantity at this point
Quote
hey I can hook up blinky LEDs too!
Old Sep 16, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
lol true [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 16, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
Brake Torquing - I.E. to hold the brake down while flooring it in gear presents no real threat to the brakes (brake-stands are a different story).
The two things that get stressed under brake torquing are: the engine mounts and the torque converter.
If you regularly maintain the vehicle the torque converter wont give you a problem (unless you launch every stop with a max stall speed brake torque) however over time the engine mounts wil likely break (brake break no pun intended) .
Anyway, brake torquing is perfectly acceptable, I wouldn't worry two much about launching the car occasionally with a brake torque.
Neutral drops are different and will destroy your tranny in NO TIME!
BTW you can not choose the maximum rpm to brake torque at, that is set by the stall speed of your converter (think two fans in a thick fluid).
most cars have a stall speed of 22-3300 rpm. Race cars have 5000RPM stalls.
Old Sep 16, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
One thing to keep in mind about brake torquing (or brake stands/power braking)...these all cause your ATF temperature to skyrocket. If you do alot of any of these you'll want to change your ATF at much earlier intervals. Switching to a synthetic like Amsoil would be a good idea also.
Old Sep 16, 2002
IronFist's Avatar
Quote
[hr]Originally posted by: mattskav
most cars have a stall speed of 22-3300 rpm. Race cars have 5000RPM stalls.[hr]
Ok. What does stall speed mean? What happens if it happens?
IronFist
Old Sep 16, 2002
PESTLNC's Avatar
Here ya go: How torque converters work
Old Sep 16, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
what about power shifting? hehe has anyone does this?
Old Sep 16, 2002
PESTLNC's Avatar
If done right it shouldn't do any harm to a MT, but it's very hard to do right.
Old Sep 16, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Quote
[hr]Originally posted by: PESTLNC
If done right it shouldn't do any harm to a MT, but it's very hard to do right.[hr]
I thought you could only do this to automatics? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 16, 2002
PESTLNC's Avatar
I was refering to power shifting, not the brake torquing.
Old Sep 16, 2002
TwilightX's Avatar
oop, my bad
Old Sep 16, 2002
aznsmtboy's Avatar
aznsmtboy is on a distinguished road
I see too many kids doing those neutral drops. [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] for god sakes, get a manual.
Old Sep 16, 2002
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
i only brake torque when im racing..maybe 5 times a month
i only brake torque at the track. mine only goes up to 2800rpms
i dont think it will really hurt unless you do it often.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
TiggerDX
Jun 18, 2015 01:43 PM
McLean
Jun 13, 2015 10:32 AM
Star1967
Jun 8, 2015 04:23 AM
Sparty
Nov 15, 2001 04:55 PM
