how fast
Old Sep 4, 2002
corruptnu2's Avatar
corruptnu2 is an unknown quantity at this point
how fast
wondering this. If I am doing 140-150 km/hr on the on the freeway is this hurting the engine at all? also what would be hurting the engine I mean at what speed
whould u be wareing out the engine if at all.
Old Sep 4, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
uhh what would that speed be in the us? hehe
Old Sep 4, 2002
RallyEX's Avatar
RallyEX is an unknown quantity at this point
that's about 84-90mph for you geniuses who paid no attention to metric conversion in high school
if you are doing this in 3rd gear yes, 4th gear maybe, 5th gear not at all.
if you have an automatic, as long as its in overdrive you are fine.
Old Sep 4, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
that's about 85-90 mph. shouldn't hurt your engine, but it will wear it out quicker cause you're cruising at what, like 5000 rpm, so the engine will just go through more revolutions per minute while cruising. i dunno - what's the hurry anyway?
Old Sep 4, 2002
corruptnu2's Avatar
no first of all i have a standard and yes I am in 5th gear and the rpm is only at 4100 at 145kph I am at this for aprox a 25 min drive to work
Old Sep 4, 2002
injencivic's Avatar
u should be fine
Old Sep 4, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Dude...at that engine speed, VTEC hasn't even engaged[IMG]i/expressions/laugh2.gif[/IMG]
Old Sep 4, 2002
Royando's Avatar
Royando is an unknown quantity at this point
take the bus next time and stop whinning
Old Sep 4, 2002
Grey's Avatar
DIY King
Theoretically the higher you rev the more your engine components wear out. If you typically rev high all the time then change out your spark plugs every 15,000 miles and change out your oil every 3,500 miles.
Old Sep 4, 2002
criminal's Avatar
criminal is an unknown quantity at this point
r u tryin to say that ur runin 5 thousand rpms at 84-90 mph........i dont think thats right cuz i cruise in my auto on the interstate at about 90-95 and i dont think i hit 5 thousand
Old Sep 4, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
[hr]Originally posted by: Grey
Theoretically the higher you rev the more your engine components wear out. If you typically rev high all the time then change out your spark plugs every 15,000 miles and change out your oil every 3,500 miles.[hr]
You should do this regardless. Except 3000 miles for oil. That's how I got my RX-7 to go over 160K with the original engine. If you take care of your car it will take care of you, I promiss!
Edit: When you have an auto the final drive ratio is lower than in a 5sp. therefore your revs will be lower.
Old Sep 4, 2002
corruptnu2's Avatar
no i never said that someone else did i said 4100 rpm
Old Sep 4, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: silverdevil
Edit: When you have an auto the final drive ratio is lower than in a 5sp. therefore your revs will be lower.[hr]
The numbers are pretty arbitrary. Just remember that heat kills spark plugs and oil. The higher you rev, the hotter the engine will get. The slower you drive, the hotter the engine will get. Plus cheap oil degrades faster, so if you have a full synthetic it will break down slower than regular dino oil. Same thing with the spark plugs. Platinum will go far. Iridium will go farther. The exact mileage will vary, so you might want to take a look at the color of the oil by rubbing the dip stick off on a white piece of paper. You might want to look at the plugs up close and see if they could use a change too. The key word here is it depends!
Old Sep 4, 2002
Ducatti's Avatar
Ducatti is an unknown quantity at this point
I think you should be going faster
Old Sep 4, 2002
Civicster's Avatar
7th gen civic auto doesnt have overdrive
solarpunk70
Apr 12, 2016 11:43 AM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Sep 25, 2015 12:12 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
jonwalden68
Aug 27, 2015 12:07 PM
