Help quick please
Old Aug 30, 2002
JKEEZO's Avatar
JKEEZO is an unknown quantity at this point
Help quick please
alright... dont want to talk about it now but the left bolt that holds my header snapped (the one that sticks out from the exhaust manifold i think)
well, im supposed to be driving somewhere, i tested the car out and i cant feel anything leaking from the header, but heres the question
what would happen if my header started leaking while i was driving my car?
Old Aug 30, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
It would be really loud and you would loose power. It would feel as if your car is twice as heavy with half the HP. It won't hurt nothing, tho. You will get a check engine light but it will reset once you fix the leak. If it snapped you will have to have it drilled out. That means remove the stock manifold and drill the sucker out. I don't know the clearance but it's not a hard job to do. After that you just put another bolt in there.
Old Aug 30, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
I think youll be ok, I wouldnt be racing around though, drive it like your grandma would and you should be ok.
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
