Help, ASAP ( Mods leave this here please)
Old Aug 19, 2002
2k1CivEX's Avatar
Phi Gamma Delta - Univ. of Toledo
2k1CivEX will become famous soon enough
ok, I hooked up my Injen CAI auto, and when I was done a few things have been screwy, my right blinker is blinking really fast and my check engine light is on, my ac is kinda screwy.
If you got a link that'll fix things or suggestions from Personal experoicances, please help ASAP
Lata Eric
Old Aug 19, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
well u gotta reset the ecu by disconnecting the batter for a few minutes after installin intake.. from wut i read its to let the computer adjust to new airflow?.. and wen your blinkers blink really fast.. its becuase the bulb is out..
Mike
Old Aug 19, 2002
2k1CivEX's Avatar
well heres the deal, I don't think its the bulb going out b/c the car only has 13,000 miles on it, and secondly, I tried to disconect the negative end of the battery for 10 min and then turn it back on and when I didm the samne thing was going on..
I think it might have to do with the sensor, you use the little red small hose pies to put on the sensor on the primary intake tube right,
*FUSTRATED***
Old Aug 19, 2002
civicpride's Avatar
civicpride is an unknown quantity at this point
take the negative off again for about 10 mins. while it is off check that u hooked it up right, ur sensor might not be in there good enough. and if u have a ex, the vtec will not kick in if ur check engine light is on, some safety feature or something. peace, that is all i have to say.
Old Aug 19, 2002
civicvtec1ps's Avatar
Search and Learn
it is NOT the bulbs.. i had same problem.. just fix "groundwires" just make sure its tight enough .
problem fixed.
AIM ME = peacemaker1ps
Old Aug 19, 2002
2k1CivEX's Avatar
alright I just read somewhere that it is the groundwires for sure, which means I can fix it, woo hoo...so but oine other thing..the sensor...how does that thing go on, with the stubby short red hose connected to the stub on the side oof the primary intake, like half on the stub and nalf on the sensor holding it on...neone who can help with experiance, add me to your MSN list Ace_1234@hotmail.com
Old Aug 19, 2002
BiGDoG's Avatar
BiGDoG is on a distinguished road
Yo face it u messed up ur car...its time to junk it....may ur car R.I.P.
Old Aug 19, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
do what peacemaker1ps said. He had the same problem and fixed it by tighting the grounding wire.
Old Aug 19, 2002
Kraize2001Civic's Avatar
Kraize2001Civic is an unknown quantity at this point
Yea i had the same exact problem when i installed my injen cold air intake I jus used the washer at the end and it fixed my problem..
Old Aug 19, 2002
2k1CivEX's Avatar
ok, the blinkers and the a/c is fine now that I tightened the groudwires but the check engune light is still on, and I left the negative end of the batterery disconeccted for about 10 minutes and then put it back and started it up and the check engine light is still on!!!!!!!!!
** fustrated*** - does this mean its my sensor that needs adjusted, some1 with CAI auto take close pic of sensor install please!!! help a fellow 7thgencivic member out...
Old Aug 19, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
check your intake temp sensor, that will affect it, the plug that plugs into the side of the intake! I hade the same problem with the blinker, i was PISSED i had the bumber and all back on and theres no way to get back to that bulb without taking out the whole headligt, POS, but my ac was screwy but i went back and checked everything and my temp sensor wasnt in all the way, BTW i installedd my INJEN Cai on saturday and i LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOVEEEEEE IT [IMG]i/expressions/demon.gif[/IMG] OMG definetely worth the cheese
Old Aug 19, 2002
2k1CivEX's Avatar
i like mine too, I can feel the difference, I just don't know how the sensor goes in, the little back sensor plug doesn't fit in the sensor hole on the side of the intake, and the short little nubbie of a red hose they give you I stuck half of that on the sensor and the other half on the little nozzel on the pipe that the sensors suposed to go in, is that right?
kmarcet
Sep 26, 2015 10:25 PM
4jacks
Aug 17, 2015 01:26 PM
