Help with nitrous decision please
alright, im thinking about getting a nitrous kit...
ive heard only good things about Nitrous Express and ive been looking into getting efi stage one kit and running a 50 shot... does this sound good?? or is there any other company i should look into like venom or something...
how hard is installation (should i have it installed or try myself) and more important, if i were to take the kit out, would there be any trace of it left anywhere (would i have to replace stock parts or would taking it off be perfectly stock) or how hard would it be to return it to stock conditions
thanks for any feedback
go with nitrous express. it comes with complete instructions, read them and if you think you can install it then do it, if not pay someone.the only reall thing that wouldn't look stock if you take it out is where ever you put the jet cuz there will be a small hole.
DIY King
Have you seen this? Nitrous Express Installation
That might help to answer some of your questions. It was in the DIY section of this site.
The venom one is really cool. It has all sorts of programmable sh!!t. But damn it's expensive as hell. I was going to get that one but when i saw the price i said forget it. I went for the nx system instead. I still haven't installed it because i havent had the time yet.
Quote
[hr]Originally posted by: Grey
That might help to answer some of your questions. It was in the DIY section of this site.[hr]
i think venom is a bit too pricey for me too vokals
alright... one more question
ive heard that i should not use it in 1st or 5th gear (manual)
but since i have an automatic, will 1st be fine to use it in???
also for those with nitrous, how much of a boost does it add??
Quote
[hr]Originally posted by: JKEEZO
ive heard that i should use it in 1st or 5th gear (manual)
also for those with nitrous, how much of a boost does it add??[hr]
I thought it was the other way around...DON'T use it in 1st and 5th gear?? I'm not a nitrous guru, but 1st gear is a bit short and 5th gear doesn't have much pull. That sounds like a good way to blow an engine...
Here, this should help...
The Nitrous Post
Quote
[hr]Originally posted by: Juggaman
The Nitrous Post[hr]
Quote
whoops i left out a not... haha
crowtoo
May 11, 2015 06:50 PM
