Increase mpg fuel efficiency, tricks or mods?
Old Mar 31, 2018
Torontopaul's Avatar
Torontopaul is an unknown quantity at this point
Hi.
I was wondering if there are some tricks, products, parts or mods that can be done to improve fuel efficiency? (Automatic-non-hybrid)
(How Do I check mpg on civic)
I WANT TO MOD A CIVIC TO GET 45! MPG!
Or at least the most I can.
There must be lots of ways to improve fuel efficiency on any car including Honda Civic.
I know part of fuel effiency has to do with the fuel mix ratios. Clean air, amount of fuel, clean fuel, higher octane fuel like premium 94 or Shells Vpower premium and fuel treatments and fuel injector cleaner. I also remember seafoam engine treatment, might help. Also proper maintenance of course. I know some people use tbe ram air filter systems or some mod.
Afriend told me the ethanol in the gasoline makes the gas mileage lower and to use only 94 octane premium fuel.
But is there a way to modify or custom alterations to go beyond the normal mpg limit from the brand?
Most civics, according to internet are about 25 to 30mpg city but a few from 2001-2004 says 35 mpg city and only 27mpg on the newest civics. Except the hybrids or manual cars.
Fuel efficiency is very hard to control here in Toronto with all the lights, traffic, etc.
Before i moved to Toronto, my intrepid was getting 35 city and 45 hwy mpg, way more than the vehicle should which was great. But when I moved to Toronto, it went from 35 city mpg to 11mpg max. It was a nightmare! I had to spend alot to refill twice a week with very little driving, just local. Plus gas here is over $5 gallon.
How do I check mpg on Civic?
Im in canada so the cars are in liters/ per 100km
Idk how switch it to MPG.
Old Mar 31, 2018
Colin42's Avatar
Re: Increase mpg fuel efficiency, tricks or mods?
No way in hell you're going to get 45mpg driving in Toronto. Just stick with using regular gas, go join a hypermiler forum if you're serious about getting the best mileage
Old Mar 31, 2018
mac25's Avatar
Dr Krieger of Modification
-tires up to 40psi (dry conditions only, no fast driving or driving in wet conditions)
-don't run winter tires
-if you have vtec keep the rpm bellow 3400rpm. (but also keep the rpm down anyway)
-coast with your foot off the brake but car in drive as much as possible when coming to a stop or down hill.
-remove as much weight from the car as possible. Run small alloy rims instead of steel rims).
Get a way to measure fuel efficient so you can keep track and have fun hunting records.
Old Apr 1, 2018
Putting premium in a car designed for regular gas will actually drop your fuel economy. There are exceptions to the rule (e.g. L15B7), but the D17 is not among those exceptions.
edit
KM/L * 2.35 = MPG
conversely,
MPG / 2.35 = KM/L
or
MPG * 0.425 = KM/L
I did fancy maths to figure that one out.
Old Apr 1, 2018
Have the feeling I have seen similar thread from you..
Did you not tell us you were still without a civic a couple days ago? If yes, moot point.
Old Apr 1, 2018
You can't have fuel economy issues of any sort if you don't have a car
miles walked divided by the number of cheeseburgers it took to get that far,
and don't forget to factor in the cost of the Nikes that took you there LOL
Old Apr 1, 2018
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
torontopaul stop"n go driving hurts fuel econo especially in T.O. Not much You
Can do except making sure its at "Optimal tune." by that i mean making sure items like following are in good working order things like:
-Air Filter
-spark lugs recommend oem kind
-tires you could safely raise the psi in them by 4 psi than whats posted on the door
-using a High Quality Synthetic Oil
-Keep the windows rolled up {Only applies if Your A/C is Working}
-higher octane fuel (if Yours runs on 87 some techs i no will recommend the higher octane in
higher mileage vehicles You have to try it i guess to find out)
-Lastly drive normally no sudden taps on the accelerater
Old Nov 19, 2019
JJOAME001's Avatar
JJOAME001 is an unknown quantity at this point
Underbody tray to reduce drag under the car. Make a block off plate or rubber strip to deflect air away from the windshield wipers.
More aerodynamic mirriors.
Smaller wheels and economy tires.
I don't know how heavy your hood is but a carbon fibre hood might reduce some weight and strip out some interior to reduce weight and remove spare tire.
And if you're crazy enough put a plate to block off the wind on your rear tires, plexiglass rear windows, carbon fibre trunk.
Don't use A/C
Check online on your specific engine if there's someone who was successful with a lean burn tune.
Basically less weight and make your car more aerodynamic. And most importantly is how you drive.
rogerscivic
General
Jun 30, 2019 10:02 PM
pushmar
General 10th Gen
16
Nov 27, 2018 01:52 PM
Slicer1989
Jan 16, 2018 09:27 PM
AndrewH.
15
Nov 15, 2012 01:15 PM
EManEX
Jul 13, 2005 06:13 PM
