fuel filter replacement on 98 civic?
Old Oct 12, 2012
velozp's Avatar
velozp is an unknown quantity at this point
Hi all just want to replace the fuel filter on my 98 civic ex. It looks pretty straight forward but I have 2 concerns. Is the system pressurized and how to depressurize it? Im told just undoing the gas cap and hearing the air is enough? Im also told to disconnect one end of the battery? Does either make sense? Just dont want gas being pumped from the tank while I disconnect and replace the fuel filter. Thank you!
Old Oct 12, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: fuel filter replacement on 98 civic?
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1324& transactionid=1350076473-1847647120&posted_by=danwat12345_www.civicforums.c om&youtube_video_id=1FcJF7HaRlE[/autostream]
You could take the fuse out for the fuel pump and run the engine until it dies to relieve fuel pressure. Or, just make sure everything is completely cold and slowly loosen the fuel filter connections, letting it drip until pressure is 0.
No need to remove battery connections, just make sure the key stays out of the ignition.
mistermenphis22
Apr 3, 2016 08:06 AM
BREADFAN
Apr 15, 2015 08:58 AM
dooner24
Apr 14, 2015 07:51 PM
thesushiboy
Apr 12, 2015 02:54 AM
