Calling all electrical nerds!!!!!!
Old Nov 21, 2011
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
waddep. I reposted this in gen discussion since other gens may need this too. If some local neighborhood moderators could delete my old one? I have a 96 CX without an empty light and I would like to add an empty light since mine didn't come with one. I know once the needle drops below the empty line that I am in the poo poo land but sometimes I have others drive my car (most of the times when I'm sh!tfaced wasted ) and I have had them run out of fuel as well. Point is, I want to add one.
At empty le resistance is 105-110ohm at empty and 2-5ohm at full. I recognize that I need to hook up a circuit so that a light comes on when le resistance is 105-110 ohm. Here is where I need help from you electrical nerds since its been 7 years since my last electronics class.
How would I go about doing this as this is counter intuitive to the on/off toggle electronics that I normally install
Old Nov 21, 2011
GolNat's Avatar
Prelude Owner
Re: Calling all electrical nerds!!!!!!
Using a voltage comparator or a Zener diode would be the best. Find out what the voltage is when the resistance is 95 or 100 ohms. There are different types of Zeners that conduct at different voltages so you should be able to find one that conducts at the voltage you need. A voltage comparator is a simple circuit you can build if that is better for you.
Old Nov 21, 2011
^Warranty voider
So should I quick splice the signal wire at the pump and run an LED to where the empty light is on the dash?
Old Nov 22, 2011
GolNat's Avatar
Prelude Owner
Yes. Either at the pum
Old Nov 22, 2011
GolNat's Avatar
Prelude Owner
Yes at the pump or at a connector closer to the dash. Splice into it at the signal wire then go to your voltage comparator circuit, or Zener, then positive side of LED. You may need a resistor to step down the voltage for the resistor depending on the voltage rating of the LED. Then ground the LED.
mjdiaz89
Jun 21, 2016 09:26 PM
viperGTS
Jul 27, 2015 08:40 PM
sch2cm
Jul 21, 2015 09:58 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
jferristx
Jul 8, 2015 10:09 PM
