How do you tab out ball joint & CV axle?
Rep Power: 0 How do you tab out ball joint & CV axle?
I need assistance on replacing ball joint and cv axle, What kind of tools do you used in order to get the ball joint out & cv axle out in a 7th gen civic? Is there a certain way where you have to pry the cv axle in order to get it out? Needs further help and thanks in advance!
Live for the Twisties
Rep Power: 261 Re: How do you tab out ball joint & CV axle?
1 Post
Rep Power: 328 Re: How do you tab out ball joint & CV axle?
if u want to take off the CV axle, you will need a hub extractor.
something like this:
http://www.amazon.com/OTC-7394-Unive.../dp/B0002SRH60
use it to extract the hub and you will have access to ur CV axle. then you just yank the CV axle out.
its a real pain in the ***. i suggest you get the cv axle professional done. the tool alone is the cost of labor and its not really worth ur time (although u can rent from autozone)
but again, its a real pain in the ***. i know cuz i did it. not worth my time.
Received 1,450 Likes
Rep Power: 339 Re: How do you tab out ball joint & CV axle?
personally, i chickened out and changed the whole axle... cheaper and less hassle. I have 2 in the garage, with the outer joints gone but good axle - i will someday install new CV joints in them, but for now the new ones should hold longer.
jackoncruzpr
09-29-2015 07:59 PM
Bruce2
09-27-2015 08:45 PM
09-27-2015 11:33 AM
Joecrowe
09-24-2015 09:12 AM
