engine trouble
Old Apr 21, 2011
Uncle X's Avatar
Uncle X is an unknown quantity at this point
Angry engine trouble
I've had a oil leak for awhile now and the cause of it is a bad oil pan gasket. Just recently my check engine light came on (flashing) and the shaking is a serious issue. About every three to four days I'll throw a quart of oil in but, there's no visible leak or smoke coming out of my exhaust anymore so I don't know where the oil is disappearing to. The cap and rotor, sparks plugs, and rubber rings inside the head gasket were changed about 10 months ago. I said that because at the time at least two spark plugs where covered in oil. So I thought the sparks just needed to be replaced again but that didn't change anything. It's as if oil is getting into my cylinders. Does anyone have an idea what could be going on with my engine? And what would be the worst case possible?
Also the exhaust is putt putting and when I put my hand to the exhaust very small spots of oil cover my hand. Thank you
Old Apr 21, 2011
honda jay's Avatar
honda jay is an unknown quantity at this point
Re: engine trouble
it could be a bad head gasket. i would check the cylender psi
Old Apr 21, 2011
MelJ's Avatar
Trance Addict
Re: engine trouble
I gave you a brief description of what the flashing MIL was in your other thread.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Allecr3
May 22, 2015 01:24 PM
pincookie1
May 4, 2015 12:22 PM
deus-ex
Apr 13, 2015 12:29 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
