Overboring???
Old Apr 13, 2002
Prankster01EX's Avatar
Prankster01EX is an unknown quantity at this point
Overboring???
Ok so now I have and excuse to overbore the cylinders... What do I need to do in order to reinforce the cylinders, I have a machine shop that will do a valve job, guide job, and port and polish...on the heads for 150 bucks, and that should free up some horsepwr... but I questioned him on how much he could overbore, and what reinforcements he would need, he told me 500 for the overbore, and 50 per cylinder to install the pistons, which includes the whole 9, guaranteed 70hp, at a 3mm overbore, it's gonna cost about a grand, should I do it??? I am putting the engine back to normal after I'm done, with all the specs from honda... Is there anything that I am missing??? Could it be a daily driver, and a weekend street racer, ohhh and 55-70ft/lbs. of torque depending on the pistons... Tell me what you know, and websites or what you think, cause I don't want to wait for the turbo, and I don't really want the one I have right now anymore, I already have a buyer sooooo... what do I do now???[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 13, 2002
civicer's Avatar
civicer is an unknown quantity at this point
70 hp and 55-70torque? Are you sure of those numbers? Seems kinda high... Oh well. Keep us informed.
Old Apr 13, 2002
avenger's Avatar
avenger is an unknown quantity at this point
are you changing the stroke of the engine as well? you'll see better gains in torque with a longer stroke engine... you going to bore it out then sleeve it for strength correct?
this dude is gonna charge 1000 altogether? are you giving him drugs or what cuz thats not a bad price... but you need to remember that if your fixing up the head, putting high compression pistons on, and bore/sleeving the cylinders you really should take care of the rest of the lower end, connecting rods, crank, bearings, etc... also think about your clutch... and your boneing yourself with a turbo by raising your compression... just a thought...
Old Apr 13, 2002
604si's Avatar
604si is an unknown quantity at this point
this is very interesting. i too think the numbers are a little on the high side. sorry that my post doesn't help. but if the numbers are accurate.. a grand doesn't seem all that much.
keep us posted
Old Apr 14, 2002
I've taken all that into consideration, and I am going to reiforce the crankshaft, if I can find one other than a stock one, as well as all the little stuff,but as far as a clutch goes, the kit only runs about 400, after taxes, and if I can pull the head/engine, and get it worked, then reinstall it, then I'm sure I can replace a clutch, but hey... whatever... As far as the turbo goes, I'm going all engine on this one so far, maybe a turbo w/15lbs on a lowered comp. engine, just replace pistons, and etc. But truthfully I highly doubt going past anything more than this, and the estimate is if I take the engine out, and apart, he puts it back together, but I stick it back in. Oh and those prices don't include the crank, and etc. He is relatively reasonable however, because he is ex-mil, and I am in the military so..... I'll see... As long as I dont run it too hard as a daily driver it should run fine without the lower end and pure synthetic oil, Shoot wil all the torque I'll gain I won't need to redline it when I race, maybe... but thanks for all the help and the luck, I'll need it... any good websites???
Old Apr 14, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
That much power for a grand? Seems like a really low price
But let us know how it goes. I've also been looking into building up my D17 instead of turboing it. The gude package is what I'm drooling over right now, but I would like to see how your plan works also.
Old Apr 14, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
<< I am putting the engine back to normal after I'm done, with all the specs from honda... >>
If you bore out your engine, then you wont be able to put your engine back to "normal". Cause you are grinding away certain parts of the internals, unless you have a magic wand that would let you put everything back to normal. If you dont want to change your engine forever, then i would wait for a stroker kit, that will basically do the same thing as boring, but without the grinding. A stroker kit will cost you quite a bit more, cause it seems like you are gettin a huge deal on the bore job. Its up to you.
Old Apr 14, 2002
avenger's Avatar
a stroker kit and boreing out are kinda the same as far as displacement, but having a longer stroke will raise your torque up more... (and affect your engine's maximum revs)
Also think about cooling... boreing out a motor lowers it's ability to cool as well as stock
exturbo6
May 20, 2009 06:44 AM
exturbo6
Engine Swaps
25
Nov 18, 2008 07:29 PM
filipinop1405
Engine Swaps
Mar 10, 2008 07:10 AM
dezod
Engine Swaps
92
Aug 18, 2006 08:07 AM
DodgeNeonSRT-4
Engine Swaps
Aug 31, 2004 07:58 AM
