DIY interior trim pieces
Old Apr 8, 2002
FLY's Avatar
FLY
FLY is an unknown quantity at this point
im trying to get the piece off of the gauge cluster the little plastic round piece with the 2 screws in the top how the hell do you get that thing off it keeps getting stuck on the two little knoby thingies i tried a search but came up with nothing i could use i thought i saw a post on this earlier but couldnt find it any help???? please?
Old Apr 8, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
ya first of all..............use some periods in there somewhere[IMG]i/expressions/face-icon-small-puke.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 8, 2002
FLY's Avatar
FLY
hey thanks for the advice.......................................wise a$$
Old Apr 8, 2002
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
Mmmkay...
Basically I found the best way to remove this piece was to look under the steering column. There are like 3 screws that are in that cover around the column and you have to remove those. Then remove the piece around the streering column and you'll be able to get the piece outa the dash easier.
Bottom line...the cover (its in 2 peices) around the steering column is in the way and once you remove that you can get better access to the guage cluster (you can put your fingers under it, and remove it).
Can you manage or do you need pics?
Old Apr 8, 2002
FLY's Avatar
FLY
ill go try it without pics then if i fail miserably again i will hound you for the pics thanks [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 8, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
Pull the cluster out and it makes it easier to get it off, and yea takin the shroud off the steering wheel makes it easier.. and people reallyare critical here .. search , proper puncuation ,
SammySC
121
Apr 7, 2017 07:43 PM
ricer_em2
May 11, 2016 08:09 PM
cferry7
Oct 18, 2015 06:32 PM
dhuff
Sep 28, 2015 08:35 PM
speedlever
Sep 24, 2015 07:18 PM
