Loud squeak when i clutch
Old Sep 14, 2006
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
Everytime i press my clutch in, i can hear a loud squeaking from outside the car. I already know i have a problem wiht my release bearing, it had been rattling for a while. well it recently stopped rattling for the most part, and i noticed the squeak this morning. I dont know much about the clutch system, am i heading for a major break down or is it somethign else?
Old Sep 14, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
did you try adjusting the clutch pedal itself....i have a slight squeak once in a while and i'm gonna see if that'll make a difference....gl by the way
Old Sep 14, 2006
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
From what I understand there are two squeaking problems people generally have. One comes from the slave cylinder(heard outside the car) and the other comes from the master cylinder(heard near the pedal). There is a DIY to fix the slave cylinder squeak. I couldn't find it for you so maybe someone else can help you out in that department!
Old Sep 14, 2006
Ashhole's Avatar
Hmm its definitely from outside the car, so ill look for the diy for the slave cylinder. thx
Old Sep 14, 2006
Anathema's Avatar
The internet says Im a loser
Anathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of light
I have the sqeaking inside the car. Is there a DIY on the master cylinder?
Old Sep 14, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
^ I've had the clutch squeaks for years, it sucks
Old Sep 14, 2006
stinkypie's Avatar
From what I understand, according to the bulletin at Honda, the master cylinder is supposed to be replaced with an updated version. With my employee discount, it would still cost me $220 here at the dealership.
That one thread was rather confusing, but I'm gonna dig into it on Sunday and see if I can get mine to quit squeaking.
Old Sep 14, 2006
dma001's Avatar
dma001 is an unknown quantity at this point
I tried white lithium grease first, and it actually worked for a couple of months, but then my squeak came back. I took it in to the dealer, and they replaced the "clutch assembly" (that's what it says on the invoice) at no charge. That's been over two years ago -- so far, so good (fingers crossed).
Old Sep 14, 2006
Ashhole's Avatar
Was that for a squeak inside the car or outside?
Old Sep 14, 2006
lxcivic2k1's Avatar
I've had a squeak for well over a year now....I'm just too lazy to do anything about it since it comes and goes.
I've seen the DIY, its prolly just dirty on the bearing or whatever...just have to clean it.
Old Sep 14, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Here's the DIY. Did mine over a year ago and still squeak free. But now I'm starting to get the interior squeak...
Old Sep 14, 2006
dma001's Avatar
It was hard to tell, but I think it was more outside than inside. I applied the grease from the inside, right at the pedal hinge and on the piston-thingy (I'm not sure what it's called) right where it goes through the firewall. I worked the pedal, and after a couple of minutes, the squeak went away, but it came back after a couple of months.
Old Sep 14, 2006
AmbulanceMonkee's Avatar
I had my car in to Honda 3 times for this. It took them that many tries to fix it. I was a squeak from the engine bay, not inside the car, when i pressed or released the clutch. It did it more when the car warmed up. I had the clutch master cylinder replaced under warranty per the service bulletin, but this did not fix it. They ended up just cleaning oxidation off the slave cylinder. I haven't had a problem since. It was described by the tech as "easy" I didn't bother to look under there myself, as I'm still under warranty. I'd look at the slave cylinder, were I you. Good luck.
Old Sep 14, 2006
Anathema's Avatar
Was it under a recall? or under warranty?
Old Sep 14, 2006
stinkypie's Avatar
It isn't a recall. It's a service bulletin. If you're out of warranty, you have to pay.....unless you aren't out of warranty by a whole lot, then request "goodwill consideration" and more likely than not, the service manager and regional manager will get it covered.
Old Sep 14, 2006
R3DL1N3's Avatar
my clutch squeaks too. i've been meaning to do something about it for like a year now.
Old Sep 14, 2006
chicohonda02's Avatar
Since 2002 Baby!
i've got the sqeak too. never done anything about it. I had it lookedat once before, they told me, more or less, "I was smoking crack, they don't hear anything." Figure I'll be getting a 100,000 maintence done soon, have the dealer look at it then. U think they could flahs my milage forward to the correct numbers, since I changed guages it shows less. it should be at 100,000+-. it shows 59,500 now.
Old Sep 14, 2006
Ashhole's Avatar
well at some point today is just quit by itself, so theres prolly some build up on the slave cylinder. thanks to everyone who has helped out
Old Sep 15, 2006
bobsagator's Avatar
When my squeaked, it wasn't all the time. It will return. Just goop up the slave cylinder and be done with it.
cukaracha
Aug 29, 2015 05:27 PM
JetsterDajet
Aug 15, 2015 08:07 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
1khilari
Jul 9, 2015 08:12 PM
