a little help please
Old Sep 5, 2006
01turboed's Avatar
01turboed will become famous soon enough01turboed will become famous soon enough
so im changing the oil on my girls 01 celica and the oil filter is on realy tight and i can't get it off any tips
Old Sep 5, 2006
downsouth_em2's Avatar
downsouth_em2 has a spectacular aura aboutdownsouth_em2 has a spectacular aura aboutdownsouth_em2 has a spectacular aura about
are you trying to take it off by hand? if so, theres a tool you can get from your local auto parts store, it's an oil filter remover....it's got a grip handle and looks like a clamp that tightens up when you pull it
Old Sep 5, 2006
LiKEaFeRiO's Avatar
A) The oil filter remover tool (but where the hell can you get one right now?)
B) Take an old leather belt, wrap it around the filter and use it to help you twist off the filter by hand.
C) Stab a screwdriver and turn!
Old Sep 5, 2006
LT2004ever's Avatar
I wil fix vBPlaza today
truth, go for the belt, or else stab and screw with some sharp object, its not like u r gonna need the filter afterwards.
Old Sep 5, 2006
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
i never heard the stab and turn method b4 but if all else fails y not haha
Old Sep 5, 2006
CraigW's Avatar
Channel Lock pliers may grip it enough.
Old Sep 5, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Screw driver method is the easiest, but messiest. Be prepared for some oil in the filter to drain out.
Old Sep 5, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
Becareful, if you rip it right off you'll have a whole new set of issues!! Been there done that, it sucks!!
Old Sep 5, 2006
AmbulanceMonkee's Avatar
How long has it been since her last oil change?? Maybe spray some WD40 or silicone and see if you can get it to draw into the threads, same concept as an old nut/bolt that is stuck?? I don't know if there are any seals on the engine itself that this sort of thing would hurt tho. Also, check manual/internet and make sure toyota didn't do anything wierd like thread it backwards so you have to right instead of left.
Old Sep 5, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I have a similar method, but I use a length of rope coiled around the filter.
Old Sep 5, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
if it is a factory toyota filter (black with toyota or lexus symbols and a lot of japanese writing) installed at the dealer forget it you're not gonna get it off w/o a GOOD filter wrench...I dunno how they put it on but they are put on tight when you get the oil changed from the dealer...screwdriver will only tear the factory filter up.and the belt thing ain't gonna cut it in the torque department....
Old Sep 5, 2006
dalaw's Avatar
Bone Stock!
if the filter is on real tight, a belt type oil filter remover might not do anything but crushing the oil filter housing, which was what happened on my dad's van. I would use a custom socket that fits the top of the celica oil filter and turn it with a wrench.
Old Sep 8, 2006
civydcex's Avatar
Oil filter pliers!!! I got a set and they work great. 7 bucks!!
