Somone Help With Overheating PLZ
Old Jul 17, 2006
Da1lyDr1ver's Avatar
Unhappy Somone Help With Overheating PLZ
Ok, i need some help here,
yesterday i did a coolant drain and refill on my mom's CRV (2002). after i filled the radiator up with coolant again, i turned on the car with the heat blasting on high with the radiator cap off. i let the car sit for about 6 minutes and kept an eye on the coolant. a few bubbles came out, but i didnt need to top off the radiator with any more than i put in (i also topped off the reserve tank to its maximum). when i took the car out for a test run, i noticed that there was no heat even tho the car had been fully warmed up (temp needle just below middle). after driving for about 5 minutes, heat started to come out. well, today on my way to work, i was sitting at a stop light and i noticed that the temp needle started to creep up to the 'HOT' zone. the car kept doing this repetedly when the car wasnt moving. well, the needle went up so high that i turned on the heat out of concern.
does anyone know what could possibly be wrong? i suspect air trapped in the system, but then again, i'm not sure... would the car really get hotter and hotter during stops with just air trapped in the system? or could it be a thermostat?
someone help please?!
Old Jul 17, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
I agree, air trapped in the system. Highly doubtful that its the thermostat since it only started after you changed the coolant.
Old Jul 17, 2006
thanks for your help? anyone with anymore ideas?
Old Jul 18, 2006
s13_240sx_92's Avatar
s13_240sx_92 is an unknown quantity at this point
Check the coolant level again, after its cooled off. My guess is that there is air in the system. Does the CRV have a bleed screw?
Old Jul 19, 2006
drunkenmagnum's Avatar
i had the same problem yesterday in atlanta but i didnt add any until it started overheating and now the car wont stay cool in traffic. i also added collant but it keeps getting hot. even when i am traveling down the road the thermostat goes hot-normal-hot-normal back and forth!
if there is air in there, how do i get it out and what other problems could it be!
Old Jul 19, 2006
if heat doesnt work, theres air trapped. you're supposed to start the car cold with radiator cap off, then let the car warm to operating temp by gently revving. once its at full temp, turn heater and fan to full, watch the bubbles. you could be at this for 30 mins depending on the air inside. you can turn the ac on too to pick the fans and open the t-stat. once no more bubbles are seen, turn off car and put cap back. make sure to add coolant while the car is running to keep it close to the top. you can squeeze the radiator hose a lil too to pump coolant around. put cap back and go drive it. when it gets cold again long time later, add coolant to the overflow tank to max line.
Old Jul 19, 2006
ok i did that and it seemed to work, but when i added the collant yeasterday and the car was running then as well so whatever i did today seemed to work.
also i accedently added to much coolant,will this cause a problem other than the excess overflowing?
Old Jul 19, 2006
how much extra, if the overflow tank is filled to the top, you're prolly gonna have some splashing out the top. and if you do the bleeding technique and the bubbles dont go away or you still have an air problem, then there's a head gasket leak.
Old Jul 19, 2006
Or a stuck t-stat.
Most hondas have a bleeder nut that you remove until the coolant pisses out of the system.
Old Jul 21, 2006
i think it is the thermostat
Old Jul 22, 2006
it overheated again and i just changed the t-stat....now what?
Old Jul 22, 2006
ctx66's Avatar
Did you recently flush and fill your coolant? or did this problem just start happening out of nowhere? how many miles on your car? has the fluid ever been changed?
Old Jul 22, 2006
it just started when i went to atlanta the other day out of nowhere (after a 3 hour drive). i thought i had the problem fixed but it got hot again yesterday and today.....really hot. is it possible that i may still have some air trapped in the system because it was a little low when i added some.
also where is that bleed screw?
Old Jul 22, 2006
try a new radiator cap. is your coolant level still good after it overheated?
Old Jul 22, 2006
seems to be. i left the cap off and ran it for a while and added some more and it did not overheat. but i did the same thing wed and it was fine then too and started back again thrus. so there must be a small leak somewhere i am not catching.
Old Jul 22, 2006
overheating is generally caused by 1. loss of coolant (leaks) 2. loss of system pressure (bad cap) 3. stuck thermostat 4. air bubbles 5. blown headgasket 6. clog in system 7. bad waterpump
try a new radiator cap before considering worse outcomes
Old Jul 23, 2006
yeah it seems like 1,3,4,6
im going though and checking the problems off 1 at a time,
how would i know if the pump or gasket went bad?
Old Jul 23, 2006
headgasket is easy, have a cooling system pressure check or even a compression check, altho when i had a small gasket leak, the compression was still fine. so get a cooling system pressure check first. another way is to see if coolant mixed with oil and made a light brown milky mix in the engine.
waterpump is a hard one, but if its not working properly, coolant will not be able to move as fast as it needs to.you cant easily check that one. how many miles on your car?
Old Jul 25, 2006
50k. i think coolant is leeking from around the water pump. if water was getting in the engine,i am sure it sould of seized up by now because of the amount of coolant that it would of swallowed but i will have it checked and i will look at the oil today.
solarpunk70
Apr 12, 2016 11:43 AM
Solo Flow
Oct 4, 2015 07:52 AM
raymondxcho
Sep 29, 2015 09:00 PM
Luluharp
Sep 27, 2015 11:56 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
