How do I wire my Stoplight on my new spoiler?
Old May 13, 2006
flqu05's Avatar
flqu05 is an unknown quantity at this point
Any color wire codes or diagrams?
Old May 13, 2006
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
What spoiler is it? I think you would just use the wiring for the center brake light (the one in the rear windsheild), since you don't need the center brake light if you have a light on the spoiler. If it's stock, it probably just plugs right into the center brake light's adapter.
Old May 13, 2006
CraigW's Avatar
Remove the high mount bulb/socket and use those wires.
White/Black
Black
Old May 13, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
can't u just tap into the thre brake light wire and just ground it if it has only two wires ................ask gearbox mr diy he can give u the best answer
Old May 14, 2006
flqu05's Avatar
Found the wires. They are just inside the upper trunk where the bulb plugs into the socket. Although i did blow the fuse the first time.....
SimpleUser
Apr 24, 2021 02:54 AM
GotSiR
Mar 8, 2017 05:33 PM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
671civicLX
Jul 4, 2015 04:02 PM
