Hp to wieght
I Hunt Goats, Rams, And Mustangs.
Hp to wieght
Ive been search around trying to find the formula to figure out if my cars wieght is 2516lbs and i have 300 hp at the wheels. How much Hp do i have per lbs of my car? There is a formula i just cant find it right now. Ive been to ask.com, googled it.
Originally Posted by ex2k3
.15hp/lb would be the power/weight ratio for 2000lb car w/300hp.
You divide the power by the weight.
Weight divided by HP gives HP LBS of weight per HP.
EX: 2000 LB Car @ 300 HP = 2000/300 = 6.67 lbs per HP
Essentially, every 6.67 lbs you remove from the car will yield 1 more HP at the crank, give or take.
that would be weight to power ratio.
lb/hp=weight to power ratio
hp/lb=power to weight ratio
He said hp to weight so I thought he wanted hp/lb (power to weight) not lb/hp (weight to power). I hope this isn't confusing people
cool as long as people get it. They are both useful, but be sure if you're talking about it with people you both are talking about the same thing because it will get confusing.
Originally Posted by MajinB
yea get a roof scoop and a rice wing too!
just find a good balance. good luck
just find a good balance. good luckThread
swen30
May 17, 2012 09:07 PM
