I NEED SOME SERIOUS HELP...PLEASE
Old Feb 26, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
my day lights, interior back lighting( behind the speedometer) and tail lights dont come on( unless i hit the brake)
anyone know what's wrong because i cant see how fast im going meaning i cant drive at night
Old Feb 26, 2002
avenger's Avatar
avenger is an unknown quantity at this point
have you done anything to the dash, indiglos, etc....... or did this just happen out of the blue? something is shorting it seems
Old Feb 26, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
Yeah, either something is shorting or something is loose. I guess you can just drive at night by riding the brakes. Go get it checked out.
Old Feb 26, 2002
only thing i've done is my LED washers.
those don't come on now either.
Old Feb 26, 2002
RSXtypeIvtec's Avatar
Su Mo
maybe a fuse blew??
Old Feb 26, 2002
IRace4Fun's Avatar
IRace4Fun is an unknown quantity at this point
It's probably a fuse underneath the hood that's blown... either that or something in the wiring.
Old Feb 26, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Check Fuses, then take to dealer or dig around if u think u know what it is
Old Feb 26, 2002
Su Mo
maybe you messed up the wiring when you installed the LEDs
Old Feb 26, 2002
avenger's Avatar
coming on when the brakes come on sounds more like a short to me
Old Feb 26, 2002
thanx
anyone else???
Old Feb 26, 2002
AlphaInfinity's Avatar
AlphaInfinity is an unknown quantity at this point
Take it to the dealer dood.
Old Feb 26, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Sounds to me that your tail lights are only working when you hit the brakes means that only your brake lights are working. The brake lights and tail lights/dash lights are on two different circuits (different fuses). Disconnect all your LED wiring. Tape back up all the wires, then check the 15 amp fuse in location #2 in the fuse box under the hood. Hopefully, all you did was short out the wires and blew the fuse.
Old Feb 26, 2002
thanx rickinthescv
ima check that now
anyone else????
(thanx for the responses so far. i really appreciate it:tup[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
woohooooooooo
rickinthescv you were right
thanx again to everyone who posted
gotta luv you guys and gals
peace
Old Feb 26, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
PGC!!!! WOOOO!
Old Feb 26, 2002
<< PGC!!!! WOOOO! >>
damn stragiht
greatest county in the MD/DC area
Old Feb 26, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
Retrace the wires on that circuit and make sure none of them are pinched. It's a pain in the a$$ but most likely that's what the prob is. The same thing happened to my friend's GSR and it was really easy to fix, but took two hours to figure out it was a pinched wire and then find it.
Old Feb 26, 2002
ricerocket's Avatar
ricerocket is an unknown quantity at this point
it gotta be the fuse just look at the fuse that goes with that light and see if it is blown ( it shoudl looks blacks and smoky indside the fuse)
Old Feb 26, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Usually when your dash lights don't work your tail lights don't work. Maybe honda came out with some neat little way of letting you know. It doesn't sound like its anything with your dash because they would either work or not work. I think the dash flashing when you hit your brakes is a sign of your tail lights not working. Check out your tail lights and let us know. You probaby just shorted the fuse to your tail lights. Where did you tap into 12v for the LED washers?
Zygrene
Mar 22, 2016 12:36 PM
Islesfan
Sep 29, 2015 03:42 AM
