so I just blinded myself a little
Old Feb 19, 2006
Meet this little guy. I plugged him into a used 9v battery and got some eye damage it was so bright. Its a 1 watt LED I was gonna use for turn signals, but on 14v I imagine it will outshine the headlights. The only other problem is in about 10 seconds that thing was burning up hot. These pics were taken in my room with sunlight shining through the window.
Old Feb 19, 2006
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
wow, that is bright!!
you were going to use those in the front turn signals???? isn't that illegal??
Old Feb 19, 2006
well i was gonna get a white one for the signal, or amber.
Old Feb 19, 2006
ahhh, gotcha, that makes sense now!!
Old Feb 19, 2006
hmm actually i just thought of something...if i use that for signal only in the front, it prolly wont get hot enough cause it is flashing and not very long usually. i'm gonna make a prototype and have someone test it out.
Old Feb 19, 2006
well, if you use it the back won't the same principle apply? it is always on when the lights are on but at a lower voltage and when it is flashing it uses more voltage so it will be brighter. wouldn't that make it okay to use it up front?? mybe i am missing something?
Old Feb 19, 2006
well this is not an actual bulb. its an led on a circuitboard with + and - connections. the front signals have two filaments and separate wires for each one. so the parking light is the low filament. with the custom one I would make the big bright led only flash with the signal and then put some smaller leds around it as parking lights.
Old Feb 19, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Looks like a Luxeon. Try a 5 watt next time
Old Feb 19, 2006
Transformer_Guy's Avatar
Lost in the Matrix
Transformer_Guy is on a distinguished road
Those would make some serious strobe lights
Old Feb 19, 2006
Kadenx's Avatar
Hey Gearbox....got a good place to buy some white super bright SMD leds for a decent price?
Old Feb 19, 2006
what is SMD? the place i get mine they are just naked leds that need resistors and stuff. I'm building the bulb assembly and pieces from scratch. the so called led bulbs that you plug in are terrible. they are just 5 or 10 tiny leds that you can barely see. which is why i'm making better ones
Old Feb 19, 2006
CraigW's Avatar
SMD = Surface Mounted Device. No leads as such, solders direct to PCB.
I plan to build some markers/signals for the side mirrors. Those look like they may work well.
Old Feb 19, 2006
the problem is it gets really hot. i'm not sure if you're supposed to be cooling them somehow or maybe just not use em for long periods. they are mounted to a small heat sink but stll get hot in a few seconds.
Old Feb 19, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
thats why the turn signals turn on and off and on and off repeatedly. is that not enough to keep it cool?
Old Feb 19, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
wow that is super bright
Old Feb 19, 2006
yea i couldn't look for more than a second and even then was seeing spots for a minute.
Old Feb 19, 2006
juanotejano's Avatar
juanotejano is an unknown quantity at this point
I like that your not gonna test it your self... let some other idiot try it on his car... fvck that.
Old Feb 19, 2006
uh well if you knew me at all you would know I would sell it to the tester at cost and refund the money if anything went wrong.
Old Feb 19, 2006
sorry I forgot sarcasm doesn't come through so well via text.
Old Feb 19, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
hah thats awesome man. just get a blue one now and mount them on your roof, you'll be able to pull people over with that thing.
Old Feb 19, 2006
no problem sorry.
ya haha i think thats what the popo uses around here except in bar form. those things you can see a mile away.
Old Feb 19, 2006
Da1lyDr1ver's Avatar
i believe that reason its getting hot is because theres too much wattage running through the LED. you'll have to put some type of resistor at the + end of the led i believe (soder). i'm betting the LED will burn out and pop if you left that 9V hooked up to it. if you wanna see, than just leave it attached to the battery for a bit and see what happens.
Old Feb 19, 2006
ya lol i'll try that eventually but the thing is i calculated the resistor needed and it only requires 18 ohm which is like nothing. and when i tried with the resistor first it got so hot i had to disconnect it. i'm sure the resistor got ruined too with that heat. so i'm thinking it doesn't need one since usually leds pop in a couple secs if you dont use a resistor. i think 18 ohm is not that much and actually that was calculated with 15v assuming the alternator was running. 9v i'm sure didn't damage anything.
Old Feb 20, 2006
tinman's Avatar
Luxeons run at around 5 volts, and you use a resistor to limit the current. You have to use a wire wound resistor for these. It's normal for it to get hot.
I have 5watt luxeons in the form of flashlights. The entire aluminum body is used as a heatsink. Even then it gets quite warm after a few minutes.
When ever possible, heatsink the LED's.
Old Feb 20, 2006
hmm i'm a little confused. whats a wire wound resistor and radioshack has em? the resistor i calculated was 18 ohm which doesn't seem like much for 14v alternator.
Old Feb 20, 2006
ragingSPAM's Avatar
I just burnt my tongue
kinda off topic but gearbox i sent u a pm
Old Feb 20, 2006
tinman's Avatar
Most resistors are carbon film. Wire wound resistors are used in applications where they get hot in order to dissipate the current that you are dropping across them. Basically a carbon film resistor will at some point burn, a wire wound will not. It's made to get hot. Rat Shack MAY have some, but their stock of parts is maybe 1% of what it used to be.
Old Feb 20, 2006
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
where did you get that, i waana do my third brake light with those
Old Feb 21, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
Try Mouser or Digikey...for those WW resistors...
9V to an LED....You only need forward voltage on LEDs plus little more...its a diode...so the forward resistance is very low when its on....typ. less than few ohms depending on MFGs......so putting 9V battery to an LED is a bad idea for 1W LED...
P=V^2/R...or P = IV
P= Power in watt, V in volt, I in Amp, R in Ohm.
Mucklow
Aug 22, 2015 06:28 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
