B16 on INTEG?
Old Feb 8, 2006
pnoiracer's Avatar
pnoiracer is an unknown quantity at this point
B16 on INTEG?
I don't know if this is in the right section... I just purchased an Integ with B16 (DOHC) in it... What kind of MOTOR OIL do I use? I've searched... and it was no luck.. I'm wondering what kind of motor oil do I use.. any recommendation? thanks!
Old Feb 8, 2006
scatman's Avatar
Still in the game...
look up what the 99-00 Si uses for oil and how much
Old Feb 8, 2006
pnoiracer's Avatar
aw ok I didn't search for that...
Old Feb 9, 2006
familycar's Avatar
di dyou by chance buy that thing down in so cal. i ahve a friend that just sold his integra with a b16 but the tranny is all fugged up! was this you not many people swap out a b16 into a integra usually they will do a ls/vtec
Old Feb 9, 2006
pnoiracer's Avatar
hmmm.. I'm not.. hopefully haha.. me and my friend fully checked out the car and test drove it... car is fine... Im in norcal by the way... and yea tranny seem to be workin fine... just didn't have an air filter for the intake...
http://www.craigslist.org/eby/car/130269116.html
here's the link..
Old Feb 9, 2006
slammedSI's Avatar
slammedSI is an unknown quantity at this point
5-30 nothen else i dont care what anyone think. thats what the dealer says to use, i have a turbed 00 SI and i run royel purple 5-30, great ****.
Old Feb 9, 2006
pnoiracer's Avatar
the engine have 10-30 right now though? Is it OK to switch to 5-30 then?
Old Feb 10, 2006
familycar's Avatar
link doesnt work what color is it
Old Feb 11, 2006
pnoiracer's Avatar
ok nm... link has expired... it's in black... and yea.. I guess the alternator is bad... shortly after I turned the car on... it idles really really low almost dying.. so would I get an alternator for 99-00 civic SI? damn I feel dumb for askin this question...
Old Feb 11, 2006
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
Yup get an alternator for an si. 5-30 oil or even 5-20 will work. Make sure you match up the connectors on the alternator before purchasing. If the motor is old dont use 5-20.
Old Feb 11, 2006
pnoiracer's Avatar
the motor is pretty new.. previous owner is using 10-30... thanks alot foffie!! I will probably take out the alternator first and bring it to kragen or autozone to match the connectors.. how hard is it? to do the alternator?
shortly after I turn on the car.. the idle is really low almost dying... that should be the alternator right? coz I already tried to put different battery for it...
Old Feb 11, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
just redo everything. first thing i did when i got my car
1. plugs
2. oil
3. tire pressure
4. battery
5. alternator
Old Feb 11, 2006
pnoiracer's Avatar
I wanted to know how hard is it to remove the alternator.... ?
Old Feb 11, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
before you go buying a civic si alt just because they have b16's in them you might wanna take out yours and look at an integra of the same year's alt. the only reason i say this is my friend had me put an alt in his 91 civic hatchback b16 swap and it took a 93 integra alt. just food for thought
Old Feb 11, 2006
pnoiracer's Avatar
^^ yea that's a good thinking.. I was thinkin about that too.. but how hard is it too take it off? because I'm afraid that on my way to the shop my car will just stop in the middle of the road... everytime I turn it on.. it's almost dying... idle is really low..
Old Feb 11, 2006
Foffie's Avatar
Its a pretty easy job. The only hard part is taking the alternator out after its un-bolted un less you want to take off the axels. If you dont you get to move the alternator through a maze of rods and engine parts but it will come out. And just so you know idling low may not be an alternator. Go to kragen and have them test it out on your car. I use to work there. Its a free service done right on the vehicle. But idlin low can be a # of things including timing, bad sensors, plugs, wires, distributor blah blah blah. And the alternator rarely has anything to do with your rpms being low. Your just feeding electricity to the car. But test it out anyway just to make sure. and how many miles are on the motor and the car?? Oh and as far as prices. Honda is as a rule of thumb cheaper than acura parts. I did the research when i worked there. And acura and honda engines although made by the same people have different bolt patterns, amps, and wiring. Dont know why but the do. That only for alternators though and some starters. and im now rambling..........
Old Feb 11, 2006
Slow Gold's Avatar
its not hard to take off. loosen the bolts you can get at from the top then jack up the car and pull it out from under. once you have it off look on ebay for pics of the alt.
Old Feb 11, 2006
Slow Gold's Avatar
Riddle me this. Do you happen to know the engine code as far as what b16. Or what obd it is . Also what year is the teg?
Old Feb 11, 2006
pnoiracer's Avatar
As far as I know it has B16a2... I will double check... well, I'm afraid to go to kragen though because I don't wanna drive and all of the sudden car will stop/stall... that happened to me... same thing as Autozone though right? do will test it for me? coz thats more near.... I don't know.. just afraid my car will stop in the middle of the road...
Old Feb 11, 2006
Slow Gold's Avatar
If your alt dies it will stop. What years the teg?
Old Feb 12, 2006
pnoiracer's Avatar
the teg is 92... yea I tested my alternator by turning on the car and disconnecting the GROUND (black wire) terminal from the battery.. and the car was STILL ON.. that means nothing is wrong with the alternator.... so WHAT OTHER THINGS CAN CAUSE THIS? When it comes under the hood.. I only know very little about it... somebody said it might be the TIMING? or maybe something else.. damn!
I notice after I disconnected the ground terminal from the battery.. it went back to regular idle.. but the engine sounds different now... its just like it is having a hard time to breath or something... what's wrong?
Old Feb 12, 2006
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
the engine's prolly just effed up b/c the car was running w/o a filter. thats a sign that you should not have bought it. that shows that the previous owner did not take car of the car at all...i'll do some reasearch later on tomorrow and get back to you---(bestfriend has that kinda swap in his teg---we deal w/ those kinda problems a good amount)
Old Feb 12, 2006
pnoiracer's Avatar
or maybe what they say the vacuum lines?
Old Feb 12, 2006
Slow Gold's Avatar
If your gonna own that car for any length of time. If you dont want it to milk you for every last dollar, you better start reading ALOT about it untill you know that car backwards and forwards. Swaps are always a pain in the a$$. Plus there are so many things that can mess with the idle. have you tried turning the idle up on the throttle body? Take off the intake so you can see into the throttle body you will see two holes inside it plug them one at a time with your finger and see if either one plugged does anything. One of those holes travels through the intake manifold to the IACV one one goes to another sensor i dunno the name for but its underneith the intake manifold. When i had my b18 it would idle from 500 - 2000 and it ended up being the sensor on the bottom even though the code i read said IACV.
Old Feb 12, 2006
pnoiracer's Avatar
well when I bought the car from him... while he was doing the swap he told me that he also change the pistons, bearings bla bla bla in the engine... so the engine's pretty much new... I had mah friend checked it up.. it seemed to be fine... and I can't even floor it because the engine hasn't broken it yet.. I tried to call the previous owner he said he never have that kind of problem before... I'm gonna have to get somebody to check my car out...
Old Feb 12, 2006
pnoiracer's Avatar
the idle is fine now... well sometime it goes down.. sometimes it goes back to normal.. but the sound of the engine is weird... not like before...
Old Feb 12, 2006
Slow Gold's Avatar
Yeah getting it checked out is the smart thing to do. Top of your list should be a compression and leak down tests.
Old Feb 12, 2006
pnoiracer's Avatar
Yea I'd probably go to Autozone and get them check it out?
idigturbo
Aug 22, 2015 02:43 AM
Trennytrent
Jul 10, 2015 09:01 PM
Ccoop87
Jul 9, 2015 03:26 PM
imPHOrt racer
May 13, 2003 01:56 AM
M1kEzPr1NcEzZ
Apr 19, 2003 12:47 AM
