getting the gauges - question
Old Dec 23, 2005
MBison's Avatar
MBison is just really niceMBison is just really niceMBison is just really niceMBison is just really nice
Talking getting the gauges - question
Ok. I'm about to buy a triple gauge pillar from glowshift. Which gauges would you guys recommend for me to get? I have a/t and dont have a turbo. Thanks.
Old Dec 23, 2005
CivicsRdBest's Avatar
none. save your money.
Old Dec 23, 2005
aki's Avatar
aki
aki is an unknown quantity at this point
if you're NA, there's no reason to get gauges. save it for somethin else.
Old Dec 25, 2005
MBison's Avatar
anyone else?
Old Dec 25, 2005
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
get 2 gauges that just have numbers but dont say anything so you can write "i wish" on one then "i had" on the other.... then buy a boost gauge and align them as so (top) I wish (middle) I had (bottom) Boost lol....something that is true to most of us
Old Dec 25, 2005
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
voltmeter, tranny temp, rpms. i have a n/a auto that's the only **** i need to know really. rpms is helpful when stickin on a wet system.
Old Dec 25, 2005
Tragedy's Avatar
skate or die
Dude, I cannot beleive so many people post such negative remarks. If you are not going to help the guy, dont fvcking post. Such ***-hats. Guages are great for any show car. They can help you monitor engine health precisely and look good. The only instance they would look odd, is if that was your only mod. Dont worry about lame ppl's opinions, I have a trilple pillar pod, and other members do to and they look sweet.
So some guages you could get are:
Air/fuel
Oil temp
Oil Pressure
Water temp
Fuel temp
Fuel Pressure
Fuel level
Boost
Pyrometer
etc...
Old Dec 25, 2005
02blackcivic's Avatar
02blackcivic is an unknown quantity at this point
id go with air/fuel, oil pressure, and fuelpressure
Old Dec 25, 2005
trans temp, oil temp, and volts i guess. that should help out especially trans temp for auto. www.egauges.com
Old Dec 25, 2005
MBison's Avatar
thanks guys.
Old Dec 25, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
i would say a/f, oil pressure and fuel pressure. cause those are ones you don't have anyway. post up how much they were, whatever you get. im thinkin about gettin a 3 gauge A myself.
Old Dec 25, 2005
dirtySAMURAI's Avatar
I log in from time to time
air/fuel gauge was my biggest mistake. that damn thing never worked (probably installed it wrong, but wtf) and it just blinked bright freakin LEDs all over the place.
i would get oil pressure, egt, voltmeter, or something useful. it's always good to know your oil pressure is solid.
Old Dec 26, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
blah save ur money, air/fuel is a big waste of money, it is used for show. Now... wideband a/f gauge is different, it monitors real fuel to air ratio unlike narrowband but wideband cost 300+ while the autometer ones cost like 50
Old Dec 26, 2005
R1Style's Avatar
I would get A/F Volt and Oil Temp.
The A/F gauge is the funnest
Old Dec 26, 2005
not when it messes up your 02 sensor
Old Dec 26, 2005
CivicSF's Avatar
hehaeh, amen gearbox. a/f won't help you to modify your driving style, whereas knowledge of trans temp, oil temp, and volts can all save your *** if those indicate a problem before you breakdown (alternator failure, cylinder head poppin, tranny gettin too warm, etc).
Old Dec 26, 2005
a trans gauge (and cooler) should be required at the rate that the auto civics fail. if it gets too hot, just throw in neutral when you're at a light.
Old Dec 26, 2005
R1Style's Avatar
especially when it messes up your O2 sensor
Old Dec 26, 2005
hey quit messin with the noobs already
Old Dec 26, 2005
MBison's Avatar
does it really?
Old Dec 26, 2005
MBison's Avatar
im trying to get some answers here, guys. i know u know more about those stuff than i do. please give me correct answers. i really dont want to waste my money on something that'd mess anything up in my vic.
Old Dec 26, 2005
MajinB's Avatar
why would a a/f sensor screw up if you get a gauge for it?
Old Dec 27, 2005
because the gauge steals some of the voltage and guess what...the ecu uses that precise voltage output to calculate a/f ratio to make your car work.
Old Dec 27, 2005
MajinB's Avatar
just run the **** parallel...
Old Dec 27, 2005
MBison's Avatar
yea. would that fix the problem?
Old Dec 27, 2005
CivicSF's Avatar
isn't the only time that the ecu modifies the fuel input is at constant speeds in overdrive, when it only slightly leans the mixture to grab some extra mileage? i think the rom-flashed fuel map applies in all other scenarios...
so how would the voltage affect the A/F ratio dumpin into the intake? i'd assume that you guys are installing a secondary bong fitting for an A/F sensor rather than taking out the o2 sensor already installed. if not, i can see the open-loop system (without o2 sensor working) being a problem...
Old Dec 27, 2005
asian relic's Avatar
asian relic has a little shameless behaviour in the past
yeah
If I were you I wouldn't buy anything, especially if you haven't moded your car, yet.
Now, if you were to mod your car later, then cool.
But, if you still want to buy some guages then with your set up you might want a volt meter to see how your batter is and if your alt goes bad, b/c I didn't have one and my alt went bad and I just recharged my battery a couple of times, bought a battery, then decided it was my alt.
Jus' mah 2 cents, but hey it's your car and money...just make sure you enjoy it.
Old Dec 27, 2005
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
Air/fuel
Oil temp
Oil Pressure
Water temp
Fuel temp
Fuel Pressure
Fuel level
Boost
Pyrometer
etc...
Agree with him
Old Dec 27, 2005
HonCivX02's Avatar
my post was ment in humor so if you took it negative then im sorry but deal with it . (and dont act like you arent negative on this site sometimes too) By the was Bison i still got that bumper dude, let me know
Old Dec 27, 2005
the ecu calculates a/f constantly at -/+ 20% fuel trims when the throttle isn't floored.
