leaving car for 3 weeks, what to do?
Old Dec 18, 2005
Anything I should really do before leaving it? I got someone watching for thieves but how about mechanical stuff or anything I should do before starting it 3 weeks from now...thanks
Old Dec 18, 2005
ajhdragon's Avatar
7thgens official a$$hole
before starting it i would say prime the fuel system first to keep it from a ruff start.
Old Dec 18, 2005
thanks i do that anyway.
Old Dec 18, 2005
noooorb's Avatar
noooorb is an unknown quantity at this point
Ask someone to start it once a week and let it run for like 5 minutes.
Old Dec 18, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
um...just make sure someone comes by every day to make sure its still there.
Old Dec 18, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Just 3 weeks?? Take the battery out. Or nothing. I frequently don't drive mine for a month, and it starts right up. That's not a long time to store. 6 months... yeah, but not 3 weeks. They often sit longer at the dealer lot!
Old Dec 18, 2005
tinman's Avatar
That's actually WORSE for the engine, since it never gets hot enough to evaporate moisture, etc. Then you stop it, and it condenses MORE moisture.
No, a month is ok without starting the engine. Then, when you do start it, DRIVE it so it gets to full temp.
Old Dec 18, 2005
manahoonie's Avatar
just have your friend run it for a little every other day or so...
Old Dec 18, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
take the battery out and if its stored in a garage i would leave windows a tad bit open thats what the manual says
Old Dec 18, 2005
Thats what i thought. And I always try to bring it to temp when I drive it even if that means going the longer way. When I get back I'll just warm it up and take it to the freeway for a while.
Old Dec 18, 2005
Titleist71's Avatar
If it sits in one spot for a while I would add some tire press. My STi is stored and I put 50 lbs in them while it just sits there. Especially now that it is cold out.
Old Dec 18, 2005
ya if i had a garage it would be on jackstands. but out here in the lot i'm sure the rims would be gone the day after.
Old Dec 18, 2005
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Stuff oily rags in the exhaust pipe. Really.
Old Dec 18, 2005
dre2600's Avatar
Make sure nothing crawls up the exhaust to live as mentioned above. Maybe over inflate the tires a wee bit, though I've seen bikes stored over the winter on their tires for 4 months w.out jack stands and they don't have any flat spots. I'd recommend to maybe change the oil, just to get any corrosive contaminants out of the system, but even thats probably not necessary. I've left a car for a month befor when I went to Greece, came back, needed an extra crank to start, but was okay, just let it warm up for a bit.
Old Dec 18, 2005
MajinB's Avatar
i never thought anything would crawl into an exhaust...dang. ok anyways just have someone check on it to make sure the car itself is not messes with.
Old Dec 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Its 3 weeks, not months.
I'd fill the gas tank so there's no room for water to evaporate in there, park it in a lit area and leave it alone. As long as its not sitting long enough to qualify for the holiday rule (start it at Thanksgiving, Christmas, MLK, Presidents day and Easter) just park it and leave it. Mine will be in the same place from last weekend until new years, I didn't do anything special.
Old Dec 19, 2005
aki's Avatar
aki
aki is an unknown quantity at this point
Even if you're worried about engine moisture, you don't have to wait for the engine to go up to the middle for it to evaporate condensed water. They're droplets in there, not huge puddles. Running it for a couple minutes (say five) should be plenty.
Old Dec 20, 2005
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
3 weeks is nothing. Just park it in a safe place like under a streetlight at a place that has a lot of activity (although colleges during Christmas break are typically ghost towns). Lock out the trunk release to make it that much harder in case someone does break into the passenger compartment. Getting a car cover wouldn't hurt either.
sharp66
31
Jun 12, 2022 08:45 AM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
tylerginevan
Apr 27, 2015 12:29 PM
SSMatey
Apr 13, 2015 06:09 PM
