ATTN: everyone who is thinking about buying real HID
Old Feb 11, 2002
RiceBuRNeR's Avatar
Turbo Member
check this out before you go and spend $400-$600 HID simulation system.
Old Feb 11, 2002
RRCivic01's Avatar
RRCivic01 is an unknown quantity at this point
hey that's cool
Old Feb 11, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
hey riceburner
where did you get you NOKYA artci blues from?
and how much
Old Feb 11, 2002
RiceBuRNeR's Avatar
Turbo Member
ebay for $25 just search for nokya H4
Old Feb 11, 2002
o..
thanx
Old Feb 11, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
if its not real hids...it aint gona look like real hids. thats why they make hids.....plus hids use less energy and create less heat...those bulbs in that link must heat up like a ****!
Old Feb 11, 2002
S2000man01's Avatar
O RLY
Coming from someone who has HID's, trust me, they are cool as hell. Everyone looks at your car when you got 'em, and they let you see SOOO clearly at night. But they are expensive. I mean it's like 200 bucks just to replace a bulb. So it all depends on what you want to do. but I will tell you, they will look cool as hell on a civic. I've never seen a civic with them on, so if anyone gets pics, let me know!
Old Feb 11, 2002
uicmedruss's Avatar
uicmedruss is an unknown quantity at this point
you know, even if they were exactly the same color as HIDs, there's no way you'd get the brightness of HID out of a 100w bulb...
Old Feb 11, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
What the hell is that kit? How does it work? It seems like a lot of $$ for a regular light bulb system. I would just save up for a real HID myself (used).
Old Feb 11, 2002
ROBREALZCIVIC's Avatar
ROBREALZCIVIC is an unknown quantity at this point
<< It seems like a lot of $$ for a regular light bulb system. I would just save up for a real HID myself (used). >>
I hear you on that one. Wayyyyyyyyy too much for a " Simulation Kit"
Old Feb 12, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
so about how much does it cost for a real HID system juss curious
i'm not into the lighting thing and i dunn really care but juss curious
Old Feb 12, 2002
Dave's Avatar
Dave is an unknown quantity at this point
Do those ballasts even work? Looks like props to me.
Old Feb 12, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
<< so about how much does it cost for a real HID system juss curious
VoiceofId was telling me about a HID system he found for $470. not sure the details on it though.
Old Feb 12, 2002
S2000man01's Avatar
O RLY
For a "real" HID system that is actually decent, or for lights like those in the S2000 you are probably looking at about $1000. That's if you are looking for high quality.
Old Feb 12, 2002
Voiceofid's Avatar
End Bringer
i saw this here at school, but couldnt reply yesterday.... anyway
To the topic, those Catz Zeta stuff makes ur bulbs fry at least twice as fast, you are pushing more wattage to it, it's techniqually illegal and you can melt your housing, rubber/plastic/silicone. On the otherhand, True HID ranges from 500-900 dollars a set, which improve 30% visibility, uses 1/2 of the power of an average halogen bulb and runs not as cold as a standard bulb either!
Now, to Ben's comment, I found a group buy on groupbuycenter.com for Philips True HID plug n' play set for 470 dollars shipped, I think that's a great deal, and can't wait till I save enough money to buy it!
Old Feb 12, 2002
Voiceofid's Avatar
End Bringer
and it is here 470 dollars a set, 6000k Philips True Xenon Gas powered H.I.D. kit
I thin Philips is pretty relieable... so I'll definitly get myself a set!
Old Feb 12, 2002
UncleB's Avatar
and with a name like Philips, you can't go wrong.
Old Feb 12, 2002
Voiceofid's Avatar
End Bringer
that's right!
Old Feb 12, 2002
Dave's Avatar
Right now, they only have d2s bulbs though, which is why I didn't get it. also, if you look carefully at the pic, the bulbs aren't Philips Ultinons like they claim.
Old Feb 12, 2002
Voiceofid's Avatar
End Bringer
whats the difference?
Old Feb 12, 2002
showoff's Avatar
showoff is an unknown quantity at this point
<< On the otherhand, True HID ranges from 500-900 dollars a set, which improve 30% visibility, uses 1/2 of the power of an average halogen bulb and runs not as cold as a standard bulb either! >>
Voiceofid it is true that hid's use half the wattage (average of 35 watts at warmup and lower than 35 after), but with that in mind it doesn't get half as hot as a halogen either. I've put my HID's on for hours just to burn them in to a nice purple and they never once got even half as hot as my stocks or piaa xtreme whites. Kits range from anywhere from $375- a good grand or so. I got my kit, which is a composite osram ballast and philips d2r bulb for a nice 450 at a local shop in Jersey.
Dave d2s bulbs are the same bulbs that come in stock hid cars like audi, s2000, acura and bmw's. The only difference between a d2s(stock bulb) and a d2r (retrofit bulb) bulb is a strip of ceramic coating on the outside of the external quartz glass. The purpose of this coating is to control the amount of lumens on a retrofit and also to eliminate some glare. D2s bulbs are about 2000 lumens brighter than d2r bulbs as a result. I also heard a number of complaints about the jdm philips ultinons. They do have a higher kelvin scale than the regular philips kit, but also have less luminosity meaning its throws less usable light on the road. Kits like k2, vision and Hanabe are the best on the market today and whats best about them is you could grab a set for about $450- $550.
Old Feb 13, 2002
Toronto's Avatar
Toronto is an unknown quantity at this point
Philips Xenon Light
Old Feb 13, 2002
Dave's Avatar
Yeah, since H4 bulbs have low and high beam integrated into 1 bulb, the base of the bulb has to be covered like D2Rs otherwise it's like the high beam are always on.
Old Feb 13, 2002
Voiceofid's Avatar
End Bringer
i meant to say it doesn't run as hot as the halegen blubs, my bad on that part.. i was watching tv while i was typing that out[IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 13, 2002
Matrix's Avatar
Matrix is an unknown quantity at this point
What does HID stand for?
Old Feb 13, 2002
Voiceofid's Avatar
End Bringer
High Intensity Discharge
Old Feb 15, 2002
Nes06's Avatar
Nes06 is an unknown quantity at this point
hey showoff where in nj is this shop?
Old Feb 15, 2002
showoff's Avatar
Its called audio links its in downtown jersey city on coles street and newark avenue ask for Freddy they're cool as hell over there.
Old Feb 15, 2002
Nes06's Avatar
aiight man.....ill check it out
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
BootyDo
May 8, 2015 05:36 PM
vistec
Nov 9, 2001 05:12 PM
