shocks need help
shocks need help
hey people my shocks are blown already and been riding with neuspeed sport for sedan. i'm looking for a set of shocks that would elminate noise or problems. right now everytime i hit a bump the suspension makes clunking sound. i want to get rid of that when i pick up new shocks. is it possible?
so ur using neuspeed springs, with oem struts? bad idea...
anyways, did you notice the clunking noise before the struts were blown? or did it occure after the struts were blown? If the clunking noise was always there since the beginning, then it obviously means that the springs were installed incorrectly. If you want a good strut, i'd suggest you look into some koni yellows, actually buying some coilovers.
^ make sure the shocks are blown before you conclude they are lol
because i thought mine were blown before, but actually they were not .. haha
but anyways, aftermarket springs on oem shocks ain't a good idea anyways
the tokico (i forgot the model.. HP? blues? whatever, check out the tokico website) , i think is pretty good for the price, for normal daily drive with a mild drop
This is very common issue with 7th gen, After I had mine strrust alligned, problem solved.
Probably your struts not blown as yet.
With mild drops 1-1.5" struts can last for quite a bit.
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
