Riding the Clutch
Old Oct 28, 2005
thomasthetank's Avatar
thomasthetank is an unknown quantity at this point
Riding the Clutch
Hey, this topic has been bugging me for a while--I have a friend who says that if the clutch is fully disengaged while the engine is idling, there is no wear on the clutch and clutch components. I was taught to put the car in neutral as opposed to sitting with the clutch disengaged. Can anyone clear this up for me?
Old Oct 28, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
it might just be me but you guys are the saying the same thing.
he say - clutch out = neutral = no wear
u say - clutch out = neutral = no wear
i dont know it might just be me though
Old Oct 28, 2005
olytrojan's Avatar
Senior Member
olytrojan is an unknown quantity at this point
i think his friend is saying "clutch in + in gear = no wear"
Old Oct 28, 2005
rEkKaShInObI's Avatar
Unsalvageable
noob question: what the hell does it mean to ride the clutch?
Old Oct 28, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
it normally means to use the clutch in a way where its not all the way in or out. its how you burn the clutch. however in this case he means something seperate.
Old Oct 28, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
i'm beginning to build on a theory that when a car is in neutral w/ clutch NOT depressed and no gear is selected, the clutch is still partly engaged..... anyway.... if the clutch is disengaged, and car is idling, there should be no damage. If your friend is talking about sitting at a traffic light with the clutch down the whole time, I'm not sure if there is damage to the transmission, but the spring that keeps the pedal up will go bad eventually.
also, in your descrition, it doesnt sound like either of you are riding the clutch.
Old Oct 28, 2005
thegent's Avatar
thegent is an unknown quantity at this point
I don't know about you guys, but putting it in neutral at each and every stop sign has saved me a couple of tickets. Otherwise, you're tempted to leave the car in second gear, pop the clutch and roll through the intersection.
Old Oct 28, 2005
LiKEaFeRiO's Avatar
I was told that riding the clutch wasn't good for a manual.
Plus I don't like my left leg to resemble a horse's while my left leg looks limp lol.
Old Oct 28, 2005
thats true...... but how about having it in neutral approaching a stop sign, step into clutch, throw it into 2nd and go?
Old Oct 29, 2005
demob05's Avatar
demob05 is an unknown quantity at this point
I've got a 2002 Civic Si, and wanted to know if these have the Self Adjusting Clutches, which reduce wear significantly, meaning riding a clutch or depressing it during stop lights are virtually a non-issue now. I heard just about every car made since late 90's with stick trans have Self Adjusting clutches as standard.. can anyone confirm this??
Old Oct 29, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
wow, i've never heard of this
Old Oct 30, 2005
ncirom2003's Avatar
no matter what gear you are in, the clutch makes contact (engages) with the flywheel as long as you dont push the pedal down.
with the car in gear and clutch pedal pushed down the clutch does not wear because its not touching the flywheel, however your putting stress on the pressure plate and down the road after doing this alot your pressure plate will prematurely need replacement. also this can cause crankshaft walkout.
car in neutral with clutch down is unescasary so dont do it.
pretty much you only cause clutch wear when you are between full engagement or full dis-engagement
Old Oct 30, 2005
ncirom2003's Avatar
hmmm never heard of this, and i doubt honda would use it. it would mean it makes the clutch back off while your riding the clutch which isnt good because youll eventually not have full contact when you release the clutch. i dont think this makes any sense and there is no reason to make it, or try to make it, i dont see how it would work.
Old Oct 30, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
if you hold the clutch in while stopped like at a light or something it will wear out bearings.
Old Oct 30, 2005
sodaks2k's Avatar
sodaks2k is an unknown quantity at this point
Eventually the throw out bearing will go bad.
Old Oct 30, 2005
dalaw's Avatar
Bone Stock!
My brother said not to depress the clutch pedal for too long because it will wear out the clutch cable or something like that.
Old Oct 30, 2005
ncirom2003's Avatar
samethng sodas2k said, the throwout bearing. thats the one that goes against the pressure plate.
to the last guy about clutch cables, nope.
Old Oct 30, 2005
aki's Avatar
aki
aki is an unknown quantity at this point
When people talk of "clutch wear," that's usually the strain caused by the engine matching the RPM of transmission through the clutch plate. Holding down the clutch does wear the clutch if done extensively, but for the most part clutch wear is due to bad shifting, dropping the clutch at high RPMs, intense quick shifts.
Second, holding the clutch at a stop light won't kill your throwout bearing. Sure, it does wear it out in the long run, but chances are your clutch plate will wear out, or pressure plate crack long before that happens. Going to neutral at every light/stop sign is overkill.
Old Nov 1, 2005
02cvcEX's Avatar
02cvcEX will become famous soon enough02cvcEX will become famous soon enough
so you want us to stall at every light/stop sign?
i stand corrected by pon55. btw, riding is NOT spelled w/ an e
Old Nov 1, 2005
Zeppelin8778's Avatar
Zeppelin8778 is an unknown quantity at this point
i believe i know exactly what hes saying... (sorry if someone clarified this already, didnt read both pages, too lazy), but he means if at a stop light, is it bad for the clutch to just sit there with the pedal down (disengaged), and should you put the stick actually in the neutral positition and only depress the brake pedal. It doesnt matter whatsoever, either way the clutch is completely disengaged and there will be no wear on it. otherwise it would wear every time u pushed the pedal down to shift gears = false.
*disclaimer... i may be wrong, but this is what i was taught in auto class*
Old Nov 1, 2005
lxcivic2k1's Avatar
When I was learning to drive a manual my dad told me to keep it in neutral at stoplights. The reason in doing this is to keep pressure of the flywheel.
So basically its not bad on the clutch by keeping it depressed but its bad for the flywheel and transmission.
Old Nov 1, 2005
ncirom2003's Avatar
02cvcex thats not true
lxcivic2k1 thats not really true either
7thgeners nowadays are lazy lol, read my previous posts.
Old Nov 2, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
I ride the clutch
thats cuz i live in a steep *** hill and its a bitch to park on a hill with stick without bumping into cars therefore I have no choice but to ride/unride the clutch. Also I ride the clutch in heavy traffic. I know its bad but I dont give a crap cause I get can oem clutches for free. Just simply bring to shop and take the clutch out and bring it to auto zone and they replace it for free for lifetime.. This is because I know the people there and they think I work for a shop and work for someones car and they gave me a receipt where if I bring that to them, they will replace the item for free with a brand new one. Only bad thing was thats its oem type so it cannot hold alot of power such as turbo. I paid 100 for the oem clutch and replaced it twice already, I love burning out my clutch, also get high performance brake pads for free as well, as long as it has some ceramic left, I can bring it back and they will give me a new one...
Old Nov 2, 2005
pon55's Avatar
Hi droi lick, thats how! Yes,clutches today are self adjusting!
Old Nov 2, 2005
pon55's Avatar
i was told that it's best to NEVER leave your car in gear and ride the clutch when at a complete stop. i forgot why but it does wear out the clutch.
You are not Rideingthe clutch when you hold it down!
Old Nov 2, 2005
ncirom2003's Avatar
Originally Posted by Civic_RedLine
I ride the clutch
hahahahaha your lucky
after a while you might want to get the flywheel resurfaced, replaced (get a lightweight one )
pon55, i guess we all learn something new everyday, im definately going to read up alot on that.
Old Nov 3, 2005
02cvcEX's Avatar
am i the only one that saw this?
mrohitredd
40
Sep 9, 2017 12:03 PM
JetsterDajet
Aug 15, 2015 08:07 AM
alaga
25
Aug 13, 2015 04:42 PM
EM_WON
Jul 22, 2015 06:49 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
