transmission
Old Sep 28, 2005
andyde's Avatar
andyde is an unknown quantity at this point
transmission
I have a Civic 2001 automatic
Can anyone tell me where the Trans plug is?
Is in a allen key head?
Any pictures available?
Thanks Andyde
Old Sep 28, 2005
01civicexboy's Avatar
01civicexboy is an unknown quantity at this point
Easy..I had the same problem. Jack car up, put the stands under it. Look at the left of the car. There will be a bolt sticking towards the passenger side tire. Simply unscrew, drain fluid,then refill. I believe you are supoosed to repeat the process 3 times. Also,clear off the shaving off of the screw. Hope this helps. Any other questions, pm me.
Old Sep 28, 2005
streetglower's Avatar
the bolt is closest the passenger side. All you need is a 3/8 ratchet, no socket. You will know the bolt when you see it, a ratchet will fit into it.
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
C-Hamm
Sep 28, 2015 10:31 PM
Elciteeve
Sep 28, 2015 12:40 PM
jerry38
Sep 20, 2015 08:38 AM
