Changing Wheels/Tires
Old Jan 31, 2002
CiViCPrAnInG2k1's Avatar
i read the manual, and it says that in order for special mechanisms to the car to work, the wheel/tire should be the same just in case u change it.
so for everyone who had wheel modifications, will it affect ur driving situations or ur cars special features? ie ABS?
i drive an EX by the way.
Old Jan 31, 2002
CarbonFiberSi's Avatar
CarbonFiberSi is an unknown quantity at this point
If you use the online Tire Calc on this site you should be able to get a larger tire and rim combo that
will come as close to the factories as possible. That shoudn't mess things up too much.
Old Jan 31, 2002
dood dats da problem, i dunno how to use dat tire calculation........... call me a DUMB FU(CK
Old Jan 31, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Should only affect your speedometer reading if the wheel diameter is changed. ABS is not affected. I haven't noticed any problems with my change in tire size other than my speedometer is off by maybe 1.6 mph per 100 mph. The car does ride and handle a heck of a lot better with my 16's than with the factory wheels and tires!
Old Jan 31, 2002
BAK's Avatar
BAK
what size wheel are you wanting to go to ? 16, 17 or 18's ?
Old Jan 31, 2002
BAK, im planning to go and get some 16/17 rims
man can u help me give some measurements? what size tires? for both?
thanks alot dude !
Old Jan 31, 2002
BAK's Avatar
BAK
No problem! If you want to go with 16's then 215/50-16 is the best match, but your limited on the choice of tires (3) and that's pretty wide. most go with 205/55-16 or 205/50-16. I like the 55 wall since there are more choices in brands and there is a little more rubber on the rim. You need it in BFE where I live in Texas !! If you go with 17's then 215/45-17 or 205/45-17 is the closest match to overall diameter.
Old Jan 31, 2002
Thanx dude !
BootyDo
May 7, 2015 04:46 PM
silverdevil
20
Jun 2, 2007 04:42 PM
htowncivicEX
Jan 21, 2002 11:48 AM
NitehawkVTEC
Jan 8, 2002 12:42 AM
htowncivicEX
Nov 13, 2001 04:30 PM
