returnless fuel system
Old Jan 29, 2002
FiresVTEC's Avatar
FiresVTEC is an unknown quantity at this point
ok guys i searched for the following: returnless and returnless fuel system and got nothing. so i was just wondering what the returnless fuel system is, how it works and why its such a problem for getting some kind of forced induction...thanks
Old Jan 29, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
Hmm thats a good question I've never heard of that either
Old Jan 29, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
Basically it is what it says. Fuel only flows in one direction with our cars...to the engine. In the older civics, it would flow both ways, so that if their was too much fuel it would just go back to the tank.
Old Jan 29, 2002
Blv's Avatar
Blv
Blv is an unknown quantity at this point
well said Perfect
why is it a problem?
with the old system, fine tuning the flow of fuel to the engine is much easier, because any excess fuel will flow back to the tank, this is particularly important with forced induction where problem of burning fuel too lean or too rich arises
with the new system, flow of fuel has to be matched correctly with the correct air/fuel ratio, and programming your ECU to do that is quite tricky
Old Jan 29, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
would a VTEC controller help that out since you can adujust the fuel mapping and air/fuel ratios?>>>>>???
Old Jan 29, 2002
PerfectD3's Avatar
Yes, a VTEC controller would cure this problem
...BUT
1. VTEC controller does not work with our cars
2. The stock fuel system won't go to much farther than it already is.
Ya just can't take a squirrel and make it work like a horse!
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]Don't ask[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 29, 2002
Slammed2k1's Avatar
Slammed2k1 is an unknown quantity at this point
It is also has a constant pressue, the regulator is in the tank.
Chris
Old Jan 29, 2002
i could have sworn that i was readin a thread that said they hooked up a vtec controller to a 01
but i am not sure am i trippin????? or did some one say that??
Old Feb 6, 2002
PerfectD3's Avatar
They did, but later found out it didn't work.
The reason Honda went with a returnless fuel system....
Why else...Emissions!
With fuel not circulating back to the tank, the in tank temperatures stay low, so not as much vaporization occurs, which results in higher emissions. Damn [IMG]i/expressions/face-icon-small-puke.gif[/IMG]ULEV crap!
Old Feb 6, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
dont you mean lower emissions?
less vaporization would mean less emission
Old Feb 6, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
It sucks!
You cant have the fuel pressure rise, as the boost or N2O psi increases, so you are limited to the amount of fuel supplyed by the pump, but the RSX system flows at higher volume and psi than the 7th gen, so hopefully they will come up with something similar for our cars.
Old Feb 6, 2002
PerfectD3's Avatar
Thank you Neo. I didn't notice my mistake.
vtecbrah
May 31, 2015 01:24 PM
PJ
Sep 5, 2003 01:00 PM
PJ
Jan 27, 2002 03:53 PM
htowncivicEX
Jan 21, 2002 11:48 AM
TaiChi
Dec 17, 2001 09:09 PM
