rpm
Old Jun 23, 2005
scarypunk's Avatar
scarypunk has a little shameless behaviour in the past
rpm
can someone tell me the redline for the 01 dx ?
Old Jun 23, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
6750-6800.....
FYI: it's the same for all 7thgen Civics.
Old Jun 23, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
your peak hp is 115 at 6100 rpms. so there is no point of going past 6100. your power just dies after that. hope that helps
Old Jun 24, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
red line is 6800, and its still ok to go past that when racing for when you go into the next gear
Old Jun 24, 2005
it's not all about where peak power is.... ok, lets say you shift at 6200 in 1st, since you mentioned 6100, I assume D17A1, that would put you below 4000RPM.... so would the car be making more power before 4KRPM? or after 6200RPM?
Old Jun 24, 2005
MajinB's Avatar
well before 4k i believe. on a dyno, the power drops off like a mountain peak right after 6100. so i think its at 4k and not 6200. my opinion. don't hate me for it, just a thought.
Old Jun 24, 2005
Zzyzx's Avatar
Autocross Junky
You should be shifting AFTER peak power is reached. Since the Torque Curve is a CURVE, there will be a point, past the peak power where Torque in the current gear will equal the torque in the next Highest gear (at a lower RPM). That is your best shift point.
Old Jun 24, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
so when to shift? 6500?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
NROD315
Sep 23, 2015 03:46 PM
Juanb24
Sep 15, 2015 12:39 AM
