highest rpm reading ???
Old Jan 23, 2002
Black99Vtec's Avatar
first member with a d16 swap
Black99Vtec should not be trustedBlack99Vtec should not be trustedBlack99Vtec should not be trusted
just wondering if anybody has ever hit 8500 rpms in there car yet i did and nothing went wrong so far. i was racing and mised third and mated the gass in neutral and it slamed up to 8500 i thought i was done but it kept goin and isd runnin fine
Old Jan 23, 2002
neillove's Avatar
neillove is an unknown quantity at this point
Don't quote me on this but I am pretty sure the computer will stop you before you go too far. Experts feel free to comment!!
Old Jan 23, 2002
01CivicMike's Avatar
01CivicMike is an unknown quantity at this point
Correct.....speed limiters are very fast - you probably didn't even hot the true redline. I imagine it kicked it around 7000, and inertia took it 7100-7300. Dont keep doing it, but most likely Ok now.
Mike
Old Jan 23, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
on a 2k1 the tach dosnt even go past 8000rpms. If your talking about an Si, the rev limiter kicks in at 8100, unless you got a modded ecu...
Old Jan 23, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
but isnt it still possible to redline if you downshift too far at too high a speed?
Old Jan 23, 2002
slam2k1civic's Avatar
slam2k1civic is an unknown quantity at this point
our car will never hit 8500 rmp i try to pass 7000 and it does not let me unless we remap our computer and still it wont go over 8000rpm [IMG]i/expressions/moon.gif[/IMG]
Old Jan 23, 2002
neillove's Avatar
Disnavis has a good question there, will the rev limiter kick in on a downshift, say from 5th to 2nd at 120Km/h?? I am pretty sure it will and just lock the tires up, but I am not sure.
Old Jan 23, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
NO the rev won't kick in.......... but you will hear a unpleasent ROOOOOOOOOHHHHHH sound.......
plus ur car will lung forward because the car is being slowed down.........
the engine can't handle the gear your in at the speed ur at.........
It's a dumb idea to downshift pass the gear that it should be in......
EXSPECIALLY frum 5th to 2nd.........
Old Jan 23, 2002
neillove's Avatar
I wasn't saying I do that, just using it as an example. I love my Civic way too much to ever punish it like that!!!
Old Jan 23, 2002
if you down shift from 5 to 2 by mistake and over rev the car your motor will blow thats for sure ask any one so try not to do that or you will find out the hard way.
Old Jan 23, 2002
neillove's Avatar
Being with friends that have done it before, you can feel the car lurch forward and just have to make sure you jam that clutch back in ASAP or your engine is TOAST!!![IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jan 23, 2002
thats right!!!!!!!!!
Old Jan 23, 2002
FiresVTEC's Avatar
FiresVTEC is an unknown quantity at this point
<< Disnavis has a good question there, will the rev limiter kick in on a downshift, say from 5th to 2nd at 120Km/h?? I am pretty sure it will and just lock the tires up, but I am not sure. >>
i think if i was going that fast i would have to intentionally jam it into second gear, my shifter wont do that very easily
Old Jan 23, 2002
trevor's Avatar
trevor is an unknown quantity at this point
If your in fourth and you drop down to 1st or 2nd at to high of RPM's
you had better kiss your TRANNY goodbye[IMG]i/expressions/moon.gif[/IMG]
learned the hard way w/ my jetta
oh and it WONT lock up the tires,,,,,,cause you have no tranny gears!!!!!
Old Oct 7, 2008
acuralegend's Avatar
acuralegend is an unknown quantity at this point
Re: highest rpm reading ???
alright a few weeks ago i had a customer bring me in a 2001 civic ex with a blown engine.
after inspecting the damage to all 4 pistons with 2 holes in each 1, due to the exhaust valves i figured a broken timing belt.
WRONG the belt was fine. the tensioner is fine, cam was not seized, and the bottom pulley was fine.
i questioned the customer on this and he said he was racing and at 8k went from 3rd to 4th and missed....he hit second by mistake.
he said his tack pegged all out.
so his rev limiter kicked in but the shear weight of the car pushed this vehicle well beyond 9000 rpm.
the best part now is it keeps killing ecm's after the new engine has been replaced.
a alternator spins about 2.5 times faster than the engine. and 20,000rpm is not good to voltage regulators.
so a 3-2 miss shift= $2000 engine with install+$500 ecm install and diag+$200 alt and diag.
p.s. ouch
Old Oct 7, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
this thread is about 6 years old mang! lol. but in any case. people dont understand that just because there is a rev limiter on their ECM it doesnt mean you cant go past it. you can mechanically make your engine rev as high as you want. somehow people manage to go from redline 4th gear into 3rd or redline 3rd gear into 2nd. no rev limiter of any kind is going to guard from you from a mistake like that.
Jul 12, 2015 11:54 AM
beeemerdude
Jul 10, 2015 09:22 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
