question: headlight and fuel gauge
Old Apr 14, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
1) will the amber piece of a sedan headlight fit into a coupe headlight?
2) is it a known problem that the 7thgen fuel gauge is messed up. I asked hondawerx about 2 years ago, and he said it was. For instance sometimes I turn off my car with 4-5 bars of gas, then when i use my car again the fuel light will be on and the needles is at the lowest.
Thanks everyone
Old Apr 14, 2005
1. the amber pieces are the same size, but the clips are in different spots. It' won't stay in unless you mod it or glue it in somehow. Cause the clips on the amber won't match the holes in the headlight.
2. fuel sender is faulty. Mine would read below empty even tho there was 5 gallons left.Have it replaced under warranty and it should be better. Just tell em to try not to spill gas under your rear seat cushion like they did with mine.
Old Apr 14, 2005
ACURAwerx's Avatar
thanks box.
Do u suggest just getting coupe amber lenses then? A girl on the site who lives by me said she would give me her sedan lenses for free.
And is the fuel problem a common problem with 7thgens?
Old Apr 14, 2005
sweeteli99's Avatar
sweeteli99 will become famous soon enoughsweeteli99 will become famous soon enough
1. won't work, you has some clips you can cut off though. then it'll fit good.
2. works fine for me.
Old Apr 14, 2005
ACURAwerx's Avatar
so if i cut off the clips, itll fit?
Old Apr 14, 2005
ACURAwerx's Avatar
^^ and stay?
Old Apr 14, 2005
well no the clips hold it in place. Otherwise it'll be loose.
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
mistermenphis22
Apr 3, 2016 08:06 AM
Supramk3
Jun 11, 2015 11:13 AM
werdnahall
May 17, 2015 11:37 AM
shaejb15
Apr 26, 2015 07:44 PM
