pulleys
Old Jan 18, 2002
AnotherDopeStyle's Avatar
AnotherDopeStyle is an unknown quantity at this point
pulleys
if i change the pulleys on my ride. will it affect the performance of the air conditioner and my audio system, runing two amps. i heard it takes some power away from these, it that true?
Old Jan 19, 2002
Grey's Avatar
DIY King
It makes your alternator output 10% less than what it's outputting now. If you get an alternator which output more amps per revolution, then you'll offset the problem. Then again, an alternator that generates more power than the stock alternator will also offer more resistence to turning. Unless alternators in general could produce more power without offering more resistence? I don't know? Maybe the bigger and better alternators have ball bearings in them and other technological innovations that allow them to produce more power without actually being harder to turn than the stock alternator? You'de have to do some research. People with souped up audio systems do complain when they've added new pullies though. One guy had problems during idle at a stop light with the system cranked. That kind of stuff...
Old Jan 19, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
i have the aem pulleys! and i am running 2 power series 800 a4 amps and 3jl audio 10w6 woofers! i did have a problem it sucked so much juice that when i parked and shut the car off that i couldnt start it back up! but i have since then put in a 1 farad stiffening cap and a optima yellow top battery deep cycle and now my headlights dont flash and my car will start right up ! even if i play it for hours! dakota
Old Jan 19, 2002
Grey's Avatar
DIY King
Ah! Good deal... So, that's another way to go... Probably easier to install than a new alternator too.
Old Jan 19, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
10% less
Old Jan 19, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
I'm planning to get a monster cap for my car.......... i don't want to mess my alternator up....... my lights flash a slight when i bump my subs over 40 % the set volume.
Bonobo
Oct 2, 2015 06:58 PM
AffliictiioN
Sep 16, 2015 02:21 PM
stank
Sep 16, 2015 07:40 AM
WaryDriver
Aug 8, 2015 05:08 PM
