02 1.7 EL cluster question
Old Mar 20, 2005
JEFFOS69's Avatar
JEFFOS69 is an unknown quantity at this point
Hey guys just got my 02 EL daily driver and Im doing a few mods to it - I want to mess around with the cluster lighting and was thinking of picking up another cluster to mess around with and keep the stock one in case I want to change it back. I see the kms on the car are digital so am I ok doing this? The ECU stores the mileage on the car right? SO if I swap clusters will the mileage still be correct? Or is the mileage stored in the cluster?
Thanks in advance
-Jeff
Old Mar 20, 2005
JEFFOS69's Avatar
Oh and Ill post up some pics of my car when I get it here and put the parts on Black on black OEM kit HID's and 17's rims and dropped.
Old Mar 20, 2005
Karumba's Avatar
Boredom causes changes ;)
Not sure if ELs are different in this fashion than Civics .. but the mileage recorded in the clusters remain there - as well as being stored in the ecu. However, if you swap clusters, the new cluster would have a different mileage than the stored ecu numbers. To match the mileage on the ECU you would need to have the cluster reflashed.
Old Mar 20, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Milage will NOT carry over between clusters.
Old Mar 20, 2005
JEFFOS69's Avatar
Ok thanks for the info guys
Old Mar 21, 2005
_Viper_'s Avatar
yeah and BTW dudes i checked thi with Honada canada...
The ECU does not keep actuall mileage only the cluster does
Old Mar 22, 2005
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
If you want an easy upgrade from the 01-02 cluster, you could always try to find an 03+ cluster which looks different and uses electroluminescent lighting.
Old Mar 24, 2005
JEFFOS69's Avatar
Oh cool I didnt know that Im just getting back into hondas - Im going to look for an 03+ thanks
fatih717171
Jul 25, 2016 06:22 PM
Smokahontas123
Jul 22, 2015 10:07 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
EliseKStewart
Jul 15, 2015 11:11 AM
fatih717171
Jul 8, 2015 12:14 AM
