reverse grinding HELP!!!
Old Jan 24, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
can anyone tell me why my reverse grinds if i rev car up to 3k at neutral then shift to reverse? Ive had trhis expericence I just started my car up and revved a lil then put it on reverse while it was still in like 2k rpms. It grinded but went into gear. I had clutch in all the way. Is it bad to rev and put gear on reverse?
anycomments would be appreciated so I can clearly understand why it is bad to do that. It was my first time doing that.
Old Jan 24, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Because the mainshaft will still spin when you rev it up, even if the clutch is in. There is enough friction there to spin the shaft with no load. Put the car in a foward gear before you shift into reverse, as the foward gears have a syncro and the reverse does not. This stops the mainshaft and allows you to shift into reverse.
Old Jan 24, 2005
im stock now! T.T
thanks. I always tought it could go into reverse if engine is revved. Just not when car is moving.
Old Jan 24, 2005
GuliziaN's Avatar
Powered by Honda...
GuliziaN will become famous soon enoughGuliziaN will become famous soon enough
Good to know. Haven't grinded yet but for further usages I will remeber this.
Old Jan 24, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
uh wtf? are you trying to do reverse burnouts or something?
Bonobo
Oct 2, 2015 06:58 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Michael Durkin
Transmission
Sep 24, 2015 12:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
