replacing front speakers with components. Help!
Old Jan 17, 2005
jack123's Avatar
jack123 is an unknown quantity at this point
I'm thinking of getting component speakers for the front. How did you guys install the tweeter for a component setup? Did you actually cut up the panel to mount the tweeter? I don't want to cut up/drill holes in my panel incase I want to go back to my factory system. Where did you mount your tweeter? It is ok if the panel cutting is hidden. Should I go with coaxials instead? I'm thinking that the speaker grill is so low in the door and if I install coaxials it might not be that great an improvement. Thats why I am thinking of going with components, so I can set the tweeter higher up. Btw, I'm amping the front speakers.
Old Jan 17, 2005
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
The EL does not have factory tweeter mounts? is this the 01 - 05 models? or is this an older model?
You might be able to find tweeter mounts, very difficult to find one that fits ur car though. One option is to a hole in your door panel or you mount them with your speaker on the door, however that requires a lot of custom work.
Old Jan 18, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Or do what I did and mount the tweeter in the little mirror trim piece (the little triangle just above the door panel that covers the mirror mounting bolts on either side. I've done this on several cars now.
You can kind of see them here:
Old Jan 18, 2005
jack123's Avatar
I was thinking of mounting it on the triangle thing between the mirrors like Telly. But did you have to drill any holes through that triangle thing? How did you hide the wires? I really don't want to drill holes through it, in case I want to put my factory set up back in.
Old Jan 18, 2005
TeLLy's Avatar
Well dude, it's not hard - you do have to drill a few holes to mount it, and the wires run behind the door panel, so none are visible.
Those triangle things cost like $20 for a pair at Acura - not a big purchase at all, so you can replace very easily. Just go to the parts counter and ask for side mirror trim.
Old Jan 18, 2005
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
The 04+ ELs do have standard stock tweeters mounted in the upper area of the door panel. These tweeters were also a dealer installed option on the 01-03 models. The stock mounting location for the OEM tweeters isn't really reversible though since you have to cut a hole in the door panel, so Telly's idea seems alot cleaner and reversible.
BTW, nice EP3 seats Will.
Old Jan 19, 2005
cheukkin's Avatar
cheukkin is an unknown quantity at this point
Telly's car always looks nice and clean, but the thing hanging behind the rear mirror like underwear to me...haha..and the tweeter I also mounted on the same place.
Old Jan 19, 2005
TeLLy's Avatar
That's cause it IS underwear...it's my gf's thong.
Old Jan 19, 2005
_Viper_'s Avatar
I hope they are clean dude or do you use those as an air freshener???
Old Jan 19, 2005
TeLLy's Avatar
They're clean. In fact they get laundered every once in a while.
Old Jan 19, 2005
jack123's Avatar
so I got a pair of infinity 6002i and an amp sitting around. I would like to install the speakers and amp in my el (the speakers will be installed in the front, and if I want, i'll buy tweeters later). Where are some good places (with a good price) to get these componenets installed? What other components do I need? I know I need some amp wiring, maybe a spacer for the speakers. I'm not sure what other components an installer will charge me for. Also are there different types of amp wiring? Do I need a special kind?
Old Jan 19, 2005
TeLLy's Avatar
To do something simple like amp and speakers, why not just DIY?
Old Jan 20, 2005
jack123's Avatar
Because I am not sure how all the components will connect together. Also, I don't know how to get all those Trim parts off. Also, I have no idea what parts I need, like wires, harnesses, etc.
Old Jan 20, 2005
shmik1's Avatar
Old Jan 20, 2005
TeLLy's Avatar
Tons of DIY's for this on the site. If you're local to GTA I can help you out.
Old Jan 20, 2005
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
wow telly, ur car is looking beautiful
Old Jan 20, 2005
TeLLy's Avatar
Thanks gtracing. One day I hope you can come for a cruise with me again. Preferably blunted with hoes in the back.
Old Jan 20, 2005
gtracing's Avatar
TeLLy is my daddy
^haha definitely man, i'm hoping i'll come over again during the summer....hopefully one time i'll even drive and show u my car...and our cars can mate together...haha, and make baby el's...i'm jealous of ur ride man, everything is soo red...and clean..my car is full of dirt and snow inside...so gross, have to definitely clean it out during the spring time...
Old Jan 22, 2005
jack123's Avatar
Ok I have infinity 6.5" 6002i sitting here and I also have an Rockford Fosgate 401S amp (not mine, but i'd like to use it).
The speaker specifications are:
60 watts RMS
4 ohms
The amp sepcifications are:
100 watts RMS x 2 at 4 ohms
200 watts RMS x 2 at 2 ohms
400 watts RMS x 1 at 4 ohms in bridged mode
I would like to install these infinities in the front and power them using this amp. Is the amp too powerful? Can I still hook these two components up?
Also, if I need replace this amp at a later time, is it simple to hook up a new amp? There is no re-wiring involved right? Do I simply disconnect the wires from this amp and hook up the new amp?
Old Jan 22, 2005
TeLLy's Avatar
The amp is fine to power those speakers.
It's pretty easy to hook up a new amp, just disconnect the wires from the old amp and wire in a new one.
Old Feb 5, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Correct me if I'm wrong, but the 6002i 's are coaxial, not component speakers. Are the tweeters detachable?
I just bought these from amazon.com:
Infinity 6002si for $55 instore pickup from Circuit Shity
Old Feb 8, 2005
jack123's Avatar
Actually, I got infinity 6000cs components that I would like to install.
Old Feb 8, 2005
TeLLy's Avatar
Hey jack, was it you asking me about an install? I forget....damn weed.
Old Feb 9, 2005
jack123's Avatar
Yeah..i needed your help to install! Still waiting
Old Feb 9, 2005
TeLLy's Avatar
Next weekend?
Old Feb 9, 2005
jack123's Avatar
Anyone know a good brand for a 4 gauge amp wiring kit? One that has enough wire to setup the front component speakers in the el.
Old Feb 10, 2005
TeLLy's Avatar
For the noobified, you may as well spend a couple of extra bucks to make sure you get a complete kit. You can go to Future Shop, grab a Stinger or Phoenix Gold kit or something....
The more experienced sometimes just go to electronics shops and pick up what they need there....but even I miss items and have to go back sometimes, not a good thing at 5pm on a Sunday....
Old Feb 10, 2005
jack123's Avatar
Took a look online at the futureshop website. They are selling the Stinger SWKH4R Amplifier Kit (4 gauge) for 179.99. Is it just me or is that way too much money for wires! I thought I would be spending $60 max. Anyone know where I can get a kit for a cheaper price (ie. store in the GTA)?
Old Feb 10, 2005
TeLLy's Avatar
That's rodickorous, 180 is way too high....
Old Feb 12, 2005
jack123's Avatar
I was looking at what is included in the stinger 4 guage amp kit. It has
FEATURES:
18' Of 4 ga. HPM Blue Power Wire
3' Of 4 ga. HPM Clear Ground Wire
1 x Platinum-Plated ANL Fuse Holder With 150 Amp ANL Fuse
17' Of 18 ga. Amplifier Remote Turn-On Wire
1 x Platinum-Plated Super Surface Contact Grounding Terminal
10 x 7" Wire Ties
Protective, Snap-In Wire Grommet
Don't you need wire for the speakers themselves?? If so what gauge? It doesn't look like the kit includes it. Is there anything else I would need to wire the amp to my speakers and headunit?
What about RCA cables?
