brakes
Old Dec 29, 2004
cvc2nv's Avatar
cvc2nv is an unknown quantity at this point
brakes
I want to put rear disk brakes on my 02 civic ex. Has anyone tried this. I could use some help. Thanks
Old Dec 29, 2004
mexinaction's Avatar
i havents tried it but i know that you can put Si rear brake setup onto any 01+ civic with some little mod, correct me if im wrong
me personally i am going to go with RSX suspension all around
Old Dec 29, 2004
jfan's Avatar
There's quite a few people who have done this already. I read that it wasn't too difficult to do.
Old Dec 29, 2004
CivicsRdBest's Avatar
I too would like to do this. All you need is to find EL brakes or Si brakes, but you have to make sure of the year because the newer Si's changed to a 5-lug pattern. Good luck with that.
Old Dec 29, 2004
Go here to read about it!
Old Dec 29, 2004
usafstud's Avatar
besides for the looks, there is no real benefit of replacing the rear drums
70% of the braking is done by the front end of the car. The brakes will lock up before the tires do, so u need better tires to stop. u don't need to worry about brake fades in the back.
many people with crx autoX and road race with drums without a problem
i'm pretty sure that u'll get worse braking with the disks in the back since the master cylinder and proportioning would be off
Old Dec 29, 2004
Zzyzx's Avatar
Autocross Junky
Many of the people autocrossing with CRX's actually found that the car was slower after they swaped to Rear disks.... something about the disks that fit weighing signifigantly more then the drum setup.
Old Dec 29, 2004
HondaLuver's Avatar
Its a celebration bitches!
umm, yea... you guys haven't researched this too good...
the rear brakes actually are lighter than the drums when swapped on the 7thgen. there is better braking, we already found out the proportiat valve is the same part on ELs. and it does help the braking on our cars.... and it has been done and talked about to death.
so...
Old Dec 29, 2004
HondaLuver's Avatar
o yea, wrong fourm
Old Dec 29, 2004
civicvtec1ps's Avatar
Search and Learn
Locked.
Please look at FAQ.
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
