does Front wheel(FF layout) drift?
Old Oct 20, 2004
  #61
Zzyzx's Avatar
Autocross Junky
Originally Posted by jovenilleb
So basically, in opposing corners, if your good in drifting, drifting is more faster than grip driving. PEACE BRO.
Bzzzzzzzz wrong answer.... Unless you are doing rally, a Drift, as you describe it, is ALLWAYS the slowest way to take a turn (or group of turns for tha matter).
Originally Posted by nookiemonster
Ask zzyzx his opinion on drifting...probably THE MOST educated and competent driver on this site.
Thanks for the support, But I dont know if I'd go that far...
So, Can a FWD car drift.... Depends entirly on your definition of a drift or drifting.
the simpleist definition is to have a cars rear end Sliding out durring a turn. how you get the rear end to rotate is not important, So long as the rear end is sliding. Can a FWD car do this, Sure, No Problem, I can think of 3 ways to get this to happen in a FWD car.
now, for Racing the term Drift or Drifting has a Very different meaning then what Pop Culture has turned it in to. In racing terms, Drift angles are synomus with Slip angles, which deals directly with when a given tire makes its best traction. Simply put, most tires make there best traction at 5-10 Deg off the center axis... what this means is that a Race car when makeing its maximum traction is actualy doing more of a crab walk through a turn. Now, would you describe an F1 car, Takeing a turn, as Drifting??? with in a POP definition it most definitly isnt, but with in the race world it is.
So Like I said, weather or not a FWD can or can not drift depends entirly on your definition of Drift....
BTW, nookiemonster, if you want to see a bunch of FWD cars with oversteer problems, come out to our next autocross.... which is the 13th AND 14th next month... So no excuses this time....
Old Oct 20, 2004
  #62
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
Yeah he using the ebrake, i dont consider that a drift
Old Oct 20, 2004
  #63
h01civic's Avatar
h01civic is an unknown quantity at this point
sweet video
Old Oct 21, 2004
  #64
-Vile-'s Avatar
-Vile- is an unknown quantity at this point
Wink
Heya all, n00b to the forum here.
Interesting discussion about drifting. Lately its become very controversal as to what the definition of it actually is. Im sure you'll find that there are many different thoughts and ideology behind what is considered drifting.
As to hitting up the main topic, I believe FF cars can drift. If you go on a lose definition of drifting, your controlling an uncontrollable turn by shifting the weight of your car and using the traction of your tires to your advantage, however you see it fit. And if so, then a FF car can drift by using the E-Brake or by simply going a ridiculous amount of speed exceeding far what is necessary to take the turn then using a double brake technique + counter steer.
Simply, if you are able to lose tranction in your rear (does not matter if your car has a natural tendency or not) you are able to drift your vehicle.
Flame on me for having tried so , I've taken my 04 lx out and tried the e-braking technique several times. My friends consider it "***-dragging" and I myself do not consider it a drift, but when you throw in lots of pratice, technique, and understanding of how the vehicle operates under the circumstances with the ability to compensate for changes, I consider that drifting on ANY car.
If anyone has watched "Drift Bible," Keiichi Tsuchiya (whom I consider a pretty well know figure in the drifting world) uses the E-Brake for drifting, as well as many others do too. Drifting isn't about definitions or limitations b/c of your vehicle type, its about having fun and technique. Many people consider using the E-Brake to drift as mimicking a drift. So my final thought about this discussion is this: "If it looks like a duck, walks like a duck, quacks like a duck, then its a duck."
Drifting is for everyone, it doesn't matter what your vehicle is.
Old Oct 21, 2004
  #65
jovenilleb's Avatar
jovenilleb has a little shameless behaviour in the past
I agree on -ville-
Old Oct 22, 2004
  #66
02civicpimp's Avatar
02civicpimp is an unknown quantity at this point
AIght... I got some terms mixed. I didnt drift but I can do it, thanks for the props and I do it late at night when nobody is on my road (that I live on)
Old Oct 22, 2004
  #67
jovenilleb's Avatar
thats cool to hear civicpimp, you can also use that during pimpin'. to attract gurls!
Old Oct 23, 2004
  #68
BlackFire's Avatar
BlackFire is an unknown quantity at this point
^^^ Of course is drifting, PLUS that civic is in front of a Sylvia on a drifting track, on a drifting competition, so DONT TELL IT AINT DRIFTING CAUSE IT IS!
That driver has skills, not easy to drift on FF, but yes, that's drifting.
Old Nov 1, 2004
  #69
Austin's Avatar
Austin is an unknown quantity at this point
drift
it is entirely possible to drift in a front wheel,
it can be as easy as unbalancing ur car so the back swings, or u can use the hand brake. its simple, if the back swings, its a drift.
Old Nov 1, 2004
  #70
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
Originally Posted by cambo
drifting in a FWD car is actually powersliding.
you cannot drift FWD vechicles, you can powerslide them, but not drift them.
I'm with him. Both drifting and powersliding are forms of controlled sliding (loss of traction). The rear wheel drive term is drifting, the front wheel drive term is powersliding (if you look at the motions that each of these car types make during these moves you'll understand why). The FWD way looks a lot more like a horizontal slide whereas the RWD way looks like losing control after turning too hard (which is what it really is).
Old Nov 1, 2004
  #71
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Have fun telling the drift gurus that what "they're really doing" is "losing control."
Old Nov 1, 2004
  #72
BlueHx's Avatar
BlueHx is an unknown quantity at this point
That **** is silly. Hope you enjoy flat spots on your tires
Old Nov 1, 2004
  #73
lol. I don't mean that in any offensive way. Much props to the sick stuff they do.
I just don't call zero traction "in control"
Old Nov 1, 2004
  #74
it is silly. fun as hell to watch. I'm sure even more fun to do.
Old Nov 1, 2004
  #75
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
ohhhh no...... it's getting hot in here......
Old Nov 1, 2004
  #76
Changu-San's Avatar
Mr. Clean
how the hell is that drifting?
Old Nov 1, 2004
  #77
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
wow...fun stuff..i think do whatever suits you is all the matters
Old Nov 1, 2004
  #78
a) who are you speaking to?
b) what the hell are you talking about?
lol.
Old Nov 1, 2004
  #79
CivicRocker02's Avatar
I usually put a cucumber in my bum when I jerk off!
CivicRocker02 is an unknown quantity at this point
Why not just get a RWD car?
Old Nov 1, 2004
  #80
modoman's Avatar
^exactly... ff wont keep up with fr, period... you lose speed puttin on the ebrake, its SIMPLE physics. and yea, go embarrass yourself tryin to drift in ff, when youre "pimpin" jolly
Old Nov 1, 2004
  #81
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
i cant see the G*D D@M Video..
Old Nov 1, 2004
  #82
BlackFire's Avatar
You are kinda wrong! I would love to show you the Toyota Altezza (Lexus IS 300) when it where only available on Japan I had a video of that car turbocharged DRIFTING, the driver drifted that car really great, the IS300 is a Front Engine, RWD car, and he DID USED THE E-BRAKE TO DRIFT!! That's part of the process of how to drift, there are corners where you MIGHT NOT NEED IT on a RWD, but he did used and the car drifted great!! On drifting competition speed loss is not a big issue, so keep away your "physics" lessions and wake up, FWD FF cars CAN DRIFT IF DRIVER HAVE GOOD SKILLS.
Old Nov 1, 2004
  #83
BlackFire's Avatar
I'M SO HAPPY I FOUND THE VIDEO!! So look that Front Engine RWD Car drifting using the e-brake!! So this guy could get and take the physics class again.
Link:
Save As
Now, I hope this clears everything up and all you guys are finally convinced that E-Brake is used on Front Engine FWD as well as Front Engine RWD Cars to drift.
I know, now there will be a guy who knows everythin gand will say: "that guy doesn't know how to drift"... well.. is a professional driver, so I believe he knows more than you and me.
Old Nov 1, 2004
  #84
exclusive_vtec's Avatar
Originally Posted by Farage
well i duno. a real drift does not involve the e brake. and what that dude was doing really f's up your rear brakes.
agreed
Old Nov 1, 2004
  #85
BlackFire's Avatar
if you agreed, see the above video, you will see that real drift does involve the e-brake.
Old Nov 1, 2004
  #86
Link:
Save As
look at all the pro cars. they all have a rear brake assister. aka E BRAKE!
that car is fuggin sick. watch his front camber lol. lots of guys kick that camber way out to help break traction up front. watch that front fender...a few times it's so low the front wheels actually hit it
Old Nov 1, 2004
  #87
BlackFire's Avatar
Well.. what I noticed was negative camber on the front, I believe that the negative camber helps not to hit the fender that much when the front of the car pulls down that hard, but yes, it is really too close to the fender.
Great car tho!
Old Nov 1, 2004
  #88
Great car tho!
he gets some smoke on one of them...ouchness to the rubber
Old Nov 1, 2004
  #89
BlackFire's Avatar
Right! Sorry about that one.
Old Nov 2, 2004
  #90
kasimmmmm's Avatar
that video's funny as hell. They must've smoked their e-brakes! This is not considered to be drifting. Its called e-braking.
