exhaust pipe?
Old Oct 14, 2004
ynok20's Avatar
ynok20 is an unknown quantity at this point
exhaust pipe?
how is mandrel bent pipe made vs the way crushed bent pipe is made for an exhaust
Old Oct 14, 2004
sp3cialk's Avatar
sp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of light
i can read the future...someone is gonna tell you to search...
Old Oct 14, 2004
Mr.Modify's Avatar
yea ..that's the best thing to do..T3h Interweb OWns j00!!
Old Oct 14, 2004
ynok20's Avatar
i dont give a fu(k i already did and i quit
Old Oct 14, 2004
Mr.Modify's Avatar
dude just type Mandrel Bent Vs. Crush Bent and read on
go to google and do this or www.ask.com
Old Oct 14, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
unless you're running high hp applications, then it really doesn't matter
Old Oct 14, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
first image is mandrel bent pipes. press bent is the second image. mandrel bent pipes are the same size the whole way on the inside, press bent pipes arent and can restrict flow. mandrel costs more $
ID:	40895   Click image for larger version
Old Oct 15, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.se-r.net/header_exhaust/m...rush_bends.htm
ctx is right
Old Oct 15, 2004
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
you can make pipes according to the pipe bender. Chopper frames are all made with mandrel bent pipes. BTW, which frame shoud I get?
Old Oct 15, 2004
modoman's Avatar
^you should get a hot match frame, they make kick *** bikes if thats what youre talkin about?
Old Oct 15, 2004
steak84ss's Avatar
I think I found a Kraft-Tech I like. Rigid, 4 up, 1.5 out, 250 wide. Already got and BRAND SPANKIN NEW H.D. Evo 80" 1340, Baker 5 speed, Custom Chrome front end, Holley Screamin' Eagle 2 barrel carb. Frame is next. Can't wait to start mockin' that bad boy up. This will be my first build. I'm "BigSteak" on www.ClubChopper.com if anyone wants to learn about bikes. Great website. Wow, that was a total gratuitous plug.
Old Oct 15, 2004
ynok20's Avatar
what i want to know is how do they bend the mandrel pipe do they heat it up and bend it or what
Old Oct 15, 2004
modoman's Avatar
they put the pipe in an assembly of a couple wheels, and it will bend around the 1 wheel while the other wheel keeps the pipe moving through... theres several ways to get those smooth bends. some pipes you have to heat up before you put them in one of those wheels. also you can just heat up a pipe and bend it across something round and it will be smooth just the same
Old Oct 15, 2004
steak84ss's Avatar
PIPE BENDER!! I'm actually looking into then now. Search Pipe/Tubing Bender on google. You'll see a bunch of styles out there on the market.
Old Oct 15, 2004
modoman's Avatar
theres also high dollar machines that will bend a pipe perfectly even in sharp turns... mandrel bending just means bending a pipe smoothly without kinks
Old Oct 15, 2004
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
Crush & mandrel bent have the same basics. They both use use a bending die(wheel) and the tube is pushed around it. Mandrel bending however has a mandrel (usually a cylindrical axle, spindle, or arbor inserted into a hole in a piece of work to support it during machining) inserted into the tube to make sure there are no wrinkles.
Typical 3 ball mandrel.
Old Oct 15, 2004
ynok20's Avatar
thanks guys
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
