I need an answer
Old Oct 7, 2004
03civda's Avatar
03civda is an unknown quantity at this point
I need an answer
Okay everyone, I know that this has been addressed a dozen times here but I still do not have a definate answer as to whats going on. I have a Greddy EVO 2 and that is the only mod so far. I live in Kansas City and it rained today. My exhaust started making that bumping sound and was really annoying. My question is this, why does water affect the exhaust in this manner. What does it do to the pipes that make them bump and why doesn't it do this when it is dry. Lastly, HOW DO I FIX IT?!?!?!? Everything underneath is fine, I just put it on a week and a half ago. Thaks for your help.
Old Oct 7, 2004
Mr.Modify's Avatar
you mean like when your driving in the rain it vibrates underneath the car right? yea mine does that to....no idea why
Old Oct 7, 2004
player's Avatar
u cant fix it
what happenes is that your exhaust is hot, when the water hits it, it starts boiling (ie crakeling).. also because of the change in temperature between the exhaust gases and the water cause the metal pipes to bend slightly (expand, contact, laws of physics) so it makes that sound
u have to leanr to get used to it
Old Oct 7, 2004
smooth14's Avatar
smooth14 is an unknown quantity at this point
hmmm not sure maybe the muffler bearings are getting wet jk lol
Old Oct 7, 2004
03civda's Avatar
Thanks PLAYER. At least I have an idea why. Is there anything I can do to make it less noisey? Also, I can hear the pipes banging against something. I would assume it is banging against the rear axle. Is there anything I can do to make that stop.
Old Oct 7, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
fortunately that doesnt happen on my HP racing Jspec catback it has been raining all week here and no annoyng sound except the not too loud deep sound i love this exhaust
Old Oct 7, 2004
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
yea hold a hammer... aim at it..close ur eyes.. and hit as hard as u can
if u hit ur body part scream if u hit something else run....lol
Old Oct 7, 2004
GideoN's Avatar
GideoN is an unknown quantity at this point
I have an EVO and it does it only when it rains. The vibration is not at the rear axle, atleast not on mine but it is occuring right after the cat going towards the back. The pipe is hitting the under body right underneath the shifter. Like I said, that is what my car does when it rains. I have tried bending it but nothing. I will deal with the noise before I damage my exhaust beyond repair. Just have to get used to it.
A flaw in an excellent exhaust.
Old Oct 7, 2004
project: EM2k4's Avatar
project: EM2k4 has a spectacular aura aboutproject: EM2k4 has a spectacular aura aboutproject: EM2k4 has a spectacular aura about
^^^^ lol!!! ^^^^
Old Oct 7, 2004
Titleist71's Avatar
I have an EVO I also. And I know why it makes that loud vibrating sound like your tranny is gonna fall apart or come throught the floorpan.......I researched the problem and found the answer.
Old Oct 7, 2004
03civda's Avatar
Is there an answer? if so how do you fix it?
Old Oct 7, 2004
Titleist71's Avatar
Of course there is an answer.......what's in it for me?
Old Oct 7, 2004
03civda's Avatar
knowing that you helped someone out.
Old Oct 7, 2004
shmik1's Avatar
lol.. mine makes noise too its a Megan catback, but its not that loud or annoying it always changes in sound when temp changes/rain/etc.. I wonder how it'll sound in the winter..
Old Oct 7, 2004
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
mine simple... just put the pieces on its right place double check just to make sure everythings fine... that's all natural though, i think that bumping noise, your pipe hits the heatshield under your body... take time to observe, you'll be good.
Old Oct 7, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Your car is going to blow...
and they are all going to laugh at you
kidding.
what player said is correct
Old Oct 8, 2004
PlasmaGT's Avatar
My Baby Daddy
PlasmaGT is on a distinguished road
Is it only after you drive through a puddle? How long does the noise last?
Old Oct 8, 2004
03civda's Avatar
yes it is. also, i just put up a new post about some info I found out. A guy at a local shop told me that it was the rubber hangers slipping around
Old Oct 8, 2004
03civda's Avatar
what do you think, I talked to a number of different people and they said that sounds right
Old Oct 8, 2004
PlasmaGT's Avatar
My Baby Daddy
Honda put out a bulletin about it on the 2001 models. I have a 2002 and had the same problem. Refer to my posts in this thread. Honda fixed it for me. It was the b-pipe heat shield. It looks like you can't access the bulletin on-line anymore, but it is Bulletin number 202 put out in Feb. '02. I have it at home and can scan it in when I have a chance
Old Oct 8, 2004
03civda's Avatar
what is the b-pipe heat shield? is that the heat shield above the mid-section? did you get specifics as to what they did to fix it, and did they give you any heck about fixing it because you have an aftermarket exhaust? I found the TSB about it on Edmunds. Should I just call the dealer?
Old Oct 8, 2004
DILLIGAF's Avatar
DILLIGAF is an unknown quantity at this point
Just an edjucated guess, but maybe the water is being trapped around the heat shield area... then it boils, and the water boiling is actually your rattle? The rattling does go away on my car, then it starts again, then it goes away, then it starts again, then it goes away, then it starts again.
I could be wrong, and probably am. Dont listen to me.
Old Oct 8, 2004
PlasmaGT's Avatar
My Baby Daddy
They replaced the pipe, since the heat shield is attached to it. The bulletin shows what part number they need to replace it with. Call the dealer and see what they say. I had to take the service manager for a ride in the rain so he could hear it for himself before they did the work.
Old Oct 8, 2004
03civda's Avatar
so, they replaced the whole pipe? is there a different pipe aside from the pipe that comes off the cat and then leads to the muffler. Because I can't replace that, it's part of my exhaust (it the mid-section)
Old Oct 8, 2004
PlasmaGT's Avatar
My Baby Daddy
It's actually called Thermal Shock. The heat shield gets hot(obviously), and when you drive through a puddle the water cools the metal so fast that it changes the shape of it causing it to rattle against the exhaust.
Old Oct 8, 2004
03civda's Avatar
how long did it take them to fix it and did they cover under warranty since you have aftermarket exhaust?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Tyler93
Detailing
Oct 24, 2015 09:48 PM
Islesfan
Sep 29, 2015 03:42 AM
NROD315
Sep 23, 2015 03:46 PM
Jrosa
Sep 14, 2015 08:24 PM
