HELP! Car-hydrolocked!!!! UPDATED!
Old Sep 8, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
I was driving to school today and hit a big puddle...
the car cranks, and starts real fast but then turns off...
Do you think I'll be ok?
Help, what do I do!!
Old Sep 8, 2004
Hawk's Avatar
You boost, I-VTEC
Well its cranking so its not as bad as mine was. You need to get the whole motor flushed and have all new fluids put in it, and spark plugs. Take off the intake manifold and dump it out, you'd be surprised how much water that thing can hold
You SHOULD be ok. And please...convert your CAI to a SRI..
Old Sep 8, 2004
Hwoody77's Avatar
So if it cranks, that means I don't have any bent rods or anything right? No piston problems...?
Old Sep 8, 2004
Hawk's Avatar
You boost, I-VTEC
once again SHOULDN'T be that bad. Of course have it checked out by a profesional shop to make sure, but like i said, you're much better off then i was.
Old Sep 8, 2004
PunkingCivic's Avatar
I need TP for my bunghole
That sucks. Hopefully it just a fluid change to the all the water out.
I remember this happened to another person here and they had the fluids change it ran them like $120 at the dealer.
After you get it fixed get a AEM bypass valve and cut a section out of the CAI. That what I did. Or get a SRI.
Best of luck to you.
Old Sep 8, 2004
streetglower's Avatar
Yes do that. I had the same problem before, but I drove right threw 2 feet of water. All you really need to do is remove your spark plug cover, get the water out of the cylinders, remove your intake and put a vaccum on the TB and suck out all the water. Then drain your oil and tranny fliud about 10x. Kepp filling it up, then draining it. Eventually your car should start if you didnt hydrolock it. Put what might happen is after a few weeks your tranny might start messing up because your TPS sensor might go bad. Mine did and I needed a whole new throttle body. Good luck to you.
Old Sep 8, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Good luck watch for the puddle.
Old Sep 8, 2004
Team Hi Voltage's Avatar
Team Hi Voltage is an unknown quantity at this point
Old Sep 8, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
The rain and flooding from Frances got to ya huh? I was driving through probably half a foot of water today but I am ok.
Best of luck to ya. Hope things work out and not get too complicated.
Old Sep 8, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
AEM bypass = CRAP!
Just get a SRI. Seriously, how much power do you gain with the CAI?
Old Sep 8, 2004
SpeedFreak's Avatar
SpeedFreak is an unknown quantity at this point
I've got a cri with a bypass valve and have driven through a sheit load of deep puddles and no problems yet. So its not crap, it works.
Old Sep 8, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
WTF? If you drive through that many deep puddles you should buy a 4x4 not a Civic.
Old Sep 8, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Just saying that is asking for trouble...
Old Sep 8, 2004
Dagooseisloose's Avatar
Dagooseisloose is an unknown quantity at this point
I drove through a big puddle with my injen cai and I blew a hole in the back of my block the size of a softball. Can you say new motor. Good Luck
Old Sep 8, 2004
DaPipeLayer's Avatar
AAAAHHHHH!!!!!
DaPipeLayer is an unknown quantity at this point
1.) Open the intake manifold or just the top portion of the throttle body until you see the opening for it. If you don't have a vaccum to suck the water out, get a decent sized rag or towel that can fit in there but also suck in water. Oh yea, get a metal hanger just incase you drop the rag in there and need to get it back out.
2.) Start dipping the rag in there and pull it out, twist rag til dry then dip it again until you can see there is no more water in there.
3.) Take out the spark plugs and dry them off, they will have water on them and also clean them with either gas or WD40.
4.) Put the plugs back and try to start the car. She will struggle the first few times but she will start. Let her run for about 1 or 2 minutes then shut her off.
5.) Change the oil right away and I mean RIGHT AWAY! Change the spark plugs too. Also if you can find some, go to autozone or some place and get a bottle of that cleaner stuff that only gets rid of water in the fuel system and other areas. Another thing, on your next gas fill up, put in premuim to help clean the out the system.
6.) The car will also bog or stutter the first few times when you drive it but it will go away eventually. After about 1000 miles NO LATER change the oil again.
At this point, if she doesn't make any wierd noises your car will be fine. You may want to do a compression check to make sure. This happened to me before and I did this exact thing and the car still works fine 23,000 miles later. I don't have the car anymore, I sold it to a guy down the street and he beats her every day with no problems.
PM me if you have another questions.
Old Sep 8, 2004
civic01vtec's Avatar
looks like you will be the next k20 swapped member
Old Sep 8, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
I have had boats for a long time. In boats, it is common to get water in the motor, for example a drain plug is not installed and the boat partially sinks. Happens a lot!
The first thing to do is NOTHING. If you suspect water in the motor, DO NOTHING. If you run the motor, you are attempting to compress the water, it will not compress and it will bend rods or valves. If enough water is in the cylinder, it will crack the block. Even a big 454 will crack.
Now, safely move the vehicle away from the water. Now is the time to worry about destroying your engine more or paying for a tow truck.
Remove all the spark plugs. This allows the water to go somewhere. Pay attention, crank the motor, water may squirt out the hole. Do this a few times, if there is water inside, use a shop vacuum and pull out the water. Drain the oil. All the water should come out. A small amount will be inside. Engines usually get condensation inside them, they usually burn it up. Oil and water will not mix, so most of it will be out.
Drain the transmission if water was high enough to enter it. Better safe than sorry. Clean the plugs with brake cleaner.
On boats that were not started, nothing is usually hurt. On a car that was already running, the motor sucked up some water, how much depends on how bad the motor is. AT this point, if the timing belt did not jump a tooth, no further damage will occur. If it is bent, it is already bent.
This is a risk that a cold air box faces. Even a short ram will suck in water if submerged, but usually that is closer to three feet of water or a much bigger splash inside the engine compartment. The K & N FIPK has a shield that helps, but running into a puddle is bad.
If you want to runn puddles, get a 4 x 4 and get a snorkle.
Old Sep 8, 2004
Don't worry a new engine is only $600 or less on ebay.
Old Sep 8, 2004
Hwoody77's Avatar
Well here's what happened, I kept the CAI on because I was going to use it for intercooler piping for my turbo kit...
So I manage to start the car and its riding really rough so I drive it real slow for about 10 miles to the shop.
I remove the spark plug cover and the plugs...no water...take out the TB practically any water, so I just got an oil change and have driven the car...no problem.
I did a compression test...
Cylinder 1,2, and 3 were at around 230, cylinder 4 was at 180....is that need to worry?
Also, at first I was hearing a loud clicking sound...really LOUD, like valves tapping, but it has died down...what could that be?
Someone told me I might have some bent-rods, but wouldn't my car run like garbage?
As of right now, I give a very slight tapping sound, and the idle is a little rough, but the car drives fine...anyone know what could be the problem?
Old Sep 8, 2004
It might get worse. Make sure the valve cleanance is fine. That compression is way off. They should all be similar, and even then the specs are around 135psi per cylinder. You have engine work that would increase compression like that?
Old Sep 8, 2004
Hwoody77's Avatar
No it's pretty stock, and I think did it right...WOT and crank 3-5 times...
Old Sep 8, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Unless its already been covered, were you using a bypass valve? I have one on my CAI but if you were using one and it didnt help, I'll be converting back to stock or SRI.
Old Sep 8, 2004
Bypass valve only works if the entire filter is under water. Also, they have a tendency to fail. Someone else's just crumbled up after a year cause of cheap materials. You can still suck up water.
Old Sep 9, 2004
Hawk's Avatar
You boost, I-VTEC
Originally Posted by Prod
Also, you wouldn't bend a rod by water..... you may throw a bearing... but not bend.
Freal??
Old Sep 9, 2004
Whelan's Avatar
Whelan is an unknown quantity at this point
wow, you guys like puddles huh. I live in NE and get plenty of rain, and melting snow. Just avoid them. If you see one, stop traffic if you have to, to avoid it. I have. We have train bridges around here where Metro-North goes over the road and small underpasses. Well when it rains hard enough they flood up, Ive pulled U-turns several times or just take another route to get to where Im going or hey let the gf drive her car because to me its not a big hassle. Avoiding puddles is not a very hard thing to do. And on the highway, follow the cars prints in front of you, they already channeled the water away so stay in their line to avoide big water.
Oh yeah and P.S.- My buddy's 2000 Prelude just bent a rod from water ingestion, so it CAN happen
Old Sep 9, 2004
Other's Avatar
New Member
Other is an unknown quantity at this point
yeah that's crazy, esp if you have a lowered car... man
UltraHDGames
Jun 8, 2016 05:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Jrosa
Sep 14, 2015 08:24 PM
shaejb15
Sep 3, 2015 01:35 PM
2010 Civic
Aug 10, 2015 10:53 AM
