gst or gsx
Old Aug 23, 2004
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
gst or gsx
ok guys which would you rathe have 1995-1999 eclipse gst or a gsx
incase you did not know the gst is front wheel drive and the gsx is all wheel drive
Old Aug 23, 2004
taz757's Avatar
I'd rather have a GSX, but that's just me.
Old Aug 23, 2004
jttegx's Avatar
OMNES AD UNUM
awd of course
im guessing the gsx would take more maintance and more time to do it since its drivetrain is different. if so, i guess ill stick with the easy FF
Old Aug 23, 2004
ragingSPAM's Avatar
I just burnt my tongue
gsx all the way...all wheel drive and turbo...although it would waste more gas...i prefer gsx
Old Aug 23, 2004
sw388integra's Avatar
GSX..but break out the pocket book!! DSM's have gremlins inside...
Old Aug 23, 2004
02sleeper's Avatar
yea but you know how everyone always says all wheel drive takes up so much power well would this car be like the wrx and still kill porches(cant speel that
Old Aug 23, 2004
taz757's Avatar
Make sure you're getting a 6-bolt DSM though. I think it's the 7-bolts that have issues. Can't remember.
Old Aug 23, 2004
02sleeper's Avatar
ok im not all up on the dsm info but what is 6 bolt and 7 bolt
Old Aug 23, 2004
HyaBoosta's Avatar
GSX all the way.
Old Aug 23, 2004
wogz's Avatar
wogz is an unknown quantity at this point
if u don't plan on racing just get a gst, or if u just want to go show and drive around with a bov get a gst. Or if ur getting an auto, get a gst. If ur getting a stick and plan on racing get a gsx!
Old Aug 23, 2004
xxnoshelterxx's Avatar
xxnoshelterxx is an unknown quantity at this point
gsx all the way, i don't even think this needs to be thought about. in the gsx you'll demolish cars on the street without even trying
Old Aug 23, 2004
dvsdara's Avatar
dvsdara is an unknown quantity at this point
I'll have to go with GSX also. With the all wheel drive system, what that does is eliminate any torque steer when gunning it off the line. I test drove a GST two years ago and taking it off the line, there was some torque steer but not as much as I had read in reviews. Anyways, you also get better wet/dry traction with the GSX.
Old Aug 23, 2004
Master's Avatar
Banned by Admin
The gst is a turbo as well.
Old Aug 23, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
gsx awd
Old Aug 23, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
My friend has a GSX with a bunch of goodies and let me tell you...it is sweet. Id say get a GSX and if you run into problems, replace the parts with performance parts.
Old Aug 23, 2004
slowciv's Avatar
slowciv is an unknown quantity at this point
my friend hads one and dam was it fast, just check it out my friends had crank walk, had to get a new motor.. he had issues getting traction it would peel out till third!! if u can get the gsx cause he always had trouble getting traction from a stop
Old Aug 23, 2004
Nick's Avatar
Formerly 2blu
I would get the gst. One of my friends has a GSX and the other has a GST. When they race the GSX pulls off the line, but the GST always passes him in the end. Plus the guy with the GSX has broken all 4 of his axels twice.
Old Aug 23, 2004
dvsdara's Avatar
I test drove the GST when it was a little wet out so the roads were damped. I spun the wheels getting out of second into third. Those cars are damn quick. The only reason that I didn't end up getting it back then is because my dad talked my mom out of co-signing a loan for me back then. He knew what was up if I had a turbocharged car back then.
Old Aug 23, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Seriously, who made you ask that question? AWD all the way. The way I see it, if you can afford maintenance on a turbo Eclipse, then why not go all out and get the AWD.
Old Aug 23, 2004
Ramones's Avatar
Ramones is an unknown quantity at this point
Try to get the earlier DSMs, as the motor were built better. I think that the 96-97 were the ones that crank-walked the most. Also don't limit yourself to only the Mitsu Eclipse. The Eagle Talon and Plymouth Laser are the same cars and can be bought for less money.
If you realy want a DSM and want a sleeper get a 1st gen GSX for about 1500-2000, spend about 2 grand in mods and run 12's . But, be prepared to work on the car (so get familiar with them).
Old Aug 23, 2004
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
Originally Posted by jttegx
awd of course
DSM's aren't too shy of mechanics.
My co-worker has a 1995 GS-T.
Old Aug 23, 2004
Master's Avatar
Banned by Admin
You forgot to mention the other DSM's 3000gt/stealth. They may be heavy but still awd turbocharged v6 kicks ****.
Old Aug 23, 2004
JDMVTECB20's Avatar
JDMVTECB20 is an unknown quantity at this point
AWD ownz joo
Old Aug 23, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
i use to have a 97 gsx and it was by far the best car ive ever owned. gsx hands down.
and about crankwalk.. any motor can get it.. but yes late 95 thru 99 7 bolt motors get it more often.. i think 20% get it.. 97's getting it most often.
he must have an early model gsx with a 3 bolt rear end.. its really weak.. commonly swapped out for a 4 bolt rear end which is a hell of a lot stronger.. i think 90-92 had 3 bolts and march 92+ had 4 bolts.
Old Aug 23, 2004
specter542's Avatar
I'm NeonImpact's a55hat!
specter542 should not be trustedspecter542 should not be trustedspecter542 should not be trustedspecter542 should not be trusted
hmmmmm awd turbo sounds a lot better to m\e..
Old Aug 23, 2004
prototype's Avatar
x-factor
either 1 you get rebuild the block... the crank will walk like a ****
Old Aug 23, 2004
EnProceso's Avatar
my coworkers brother has a GSX, with a turbo upgrade and fuel management upgrade, he runs high 12's all day long. i dont even think hes done anything to the internals.
Old Aug 26, 2004
02sleeper's Avatar
sweet guys thanx for the info if i where to get a 1995 -1998 gsx and swap the motor for a older one woiuld it be a direct fit
Old Aug 26, 2004
HondaLuver's Avatar
Its a celebration bitches!
i have a 1st gen gst... i love it... total sleeper... anyways, the 2nd gen has the crank walk problem.. get the gsx, you will love it
Old Aug 26, 2004
solo_rider's Avatar
solo_rider is an unknown quantity at this point
its not even an arguement...gsx all the way
