A local Honda dealership
Old Jul 23, 2004
Texas Rice's Avatar
Texas Rice is an unknown quantity at this point
I had but a lower rear tie bar on my civic and took it up to my local dealership to have them re-align the rear suspension. Also to add to the fact I had bought some very nice and sticky falkens, I had planned to try my luck in a local auto-crossing meet. Time when by, 8000 miles to be exact, and I start to hear a clicking noise when I drive, and the noise went faster as my speed increased so obviously it was the wheels. My left rear tire was worn down to the metal threads in the middle of the tire. I am talking like a 4 inch gap of all metal ,but my right rear was not as bad but metal was coming through. I immediately took it into Discount Tire, where I had bought the tires, thinking it was a faulty tire. No, my alignment was so bad that it had worn down my brand new falkens down to nothing. I returned to Honda and get no rebate or anything.
Old Jul 23, 2004
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
damn that suks, if i were u i would cuss of honda for doing such a bad job
Old Jul 23, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
From what I gather from your post, the rest of your suspension/wheels stock except for the bar and the tires?
Old Jul 23, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
^if this is the case, hondas service department should be held liable
Old Jul 23, 2004
Texas Rice's Avatar
Yes, those are the only modifications to the rear suspension.
Old Jul 24, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
You might have a case if you could get a rear alignment on a civic, but you cant.
Old Jul 24, 2004
streetglower's Avatar
what are you talking about, I get my rear aligned all the time. My toe is mostly the thing that is out.
Old Jul 24, 2004
I will tell you this, Honda is not going to pay for that because you should be checking your tires frequently and making sure things are wearing correctly. How do they know it was there fault. They could have aligned your car perfectly and a few days later you might have hit a pothole or something and didnt think anything of it and it threw your toe or camber way out, it happens to drivers everyday. I understand were you are coming from, but there is no way to prove it was hondas fault. most likely they are thinking it was your fault for hitting something.
Old Jul 24, 2004
Mystic3030's Avatar
Sorry, correction, theres no camber adjustment in the rear
And upon re reading his post, it sounds like toe-in or toe-out WAS the problem. Again though, it's his fault for not checking his tires, and there is no way honda will pay for new tires. They usually have like a 1 week warranty on the alignment, but thats it.
Old Jul 24, 2004
There is rear camber adjustment. That is why they have rear camber kits. I have one and it adjust the camber. They also can adjust the toe in the rear. The camber in the back is when the tire sits in or out. The toe is when it sits left to right and how far in. Both can be adjusted in the rear.
Old Jul 24, 2004
Mystic3030's Avatar
No, there is no stock rear camber adjustment. The only way to have it adjustable is with an aftermarket kit.
Old Jul 24, 2004
ok that makes more since now, when you said the rear cant be adjusted at all I was like WTF? But yes it can only be adjusted with a camber kit.
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
SLeePeR012
Dec 4, 2001 12:47 PM
CivNoir
Nov 29, 2001 02:21 PM
